I am using IRLib2 and PWM for a mood light project where I have a "volatile unsigned long" variable that is used to keep the value of the last pressed key. This value is used to resolves cases in a switch case which calls the relevant function.
At first I found out that IRLib is conflicting with a few Pins. The pins where I found the PWM output correct were 5, 6 and 9, so I moved my RGB LED connections to these.
My problem is that the global variable "volatile unsigned long val;" resets to zero after some time.
My Arduino is Powered from a AC/DC Adapter.
The code is this
#include "IRLibAll.h"
//My Remote Codes
#define POWER 551489775
#define ONE 551520375
#define TWO 551504055
#define THREE 551536695
#define FOUR 551495895
#define FIVE 551528535
#define SIX 551512215
#define SEVEN 551544855
#define EIGHT 551491815
#define NINE 551524455
#define ZERO 551487735
#define RED 551505585
#define GREEN 551521905
#define YELLOW 551536185
#define BLUE 551519865
#define UP 551486205
#define DOWN 551518845
#define LEFT 551542815
#define RIGHT 551510175
#define VOL+ 551502015
#define VOL- 551534655
#define CH+ 551485695
#define CH- 551518335
IRrecv myReceiver(2);
IRdecode myDecoder;
int redPin = 9;
int greenPin = 5;
int bluePin = 6;
pinMode(redPin, OUTPUT);
pinMode(greenPin, OUTPUT);
pinMode(bluePin, OUTPUT);
setColor(255, 0, 0);
setColor(0, 255, 0);
setColor(0, 0, 255);
setColor(0, 0 , 0);
myReceiver.enableIRIn();
Serial.println("Ready!");
if (myReceiver.getResults()) {
myDecoder.decode();
//myDecoder.dumpResults(true);
if (myDecoder.value != 0xFFFFFFFF)
val = myDecoder.value;
Serial.println(val, HEX);
Serial.println(val);
switch (val) {
case RED:
fade(redPin);
case GREEN:
fade(greenPin);
case BLUE:
fade(bluePin);
case YELLOW:
fadeYellow();
case ONE:
rainbow();
case TWO:
faderTwo();
case THREE:
faderThree();
case FOUR:
faderFour();
case FIVE:
faderFive();
case SIX:
faderSix();
case SEVEN:
faderSeven();
default:
faderTwo();
void fade(int pin)
setColor(0, 0, 0);
for (int fadeValue = 0; fadeValue <=255; fadeValue += 5) {
analogWrite(pin, fadeValue);
delay(30);
for (int fadeValue = 255; fadeValue >= 0; fadeValue -=5) {
delay(30);
void fadeYellow()
setColor(255, 255, 0);
analogWrite(redPin, fadeValue);
analogWrite(greenPin, fadeValue);
delay(30);
delay(30);
void setColor(unsigned char r,unsigned char g,unsigned char b)
analogWrite(redPin, r);
analogWrite(greenPin, g);
analogWrite(bluePin, b);
//ONE
void rainbow()
int r = 148;
int g = 0;
int b = 211;
setColor(r, g, b);
setColor(75, 0, 130);
setColor(255, 127, 0);
setColor(0, 0, 0);
//TWO
void faderTwo()
setColor(255, 0, 255);
for (int fadeValue = 0; fadeValue <=255; fadeValue += 5){
delay(30);
for (int fadeValue = 255; fadeValue >= 0; fadeValue -= 5){
delay(30);
void faderThree()
// fade from green to red
for(int i=0; i<255; i++) {
analogWrite(redPin, i);
analogWrite(greenPin, 255-i);
analogWrite(bluePin, 0);
delay(30);
// fade from red to blue
analogWrite(redPin, 255-i);
analogWrite(greenPin, 0);
analogWrite(bluePin, i);
delay(30);
// fade from blue to green
analogWrite(redPin, 0);
analogWrite(greenPin, i);
analogWrite(bluePin, 255-i);
delay(30);
void faderFour()
setColor(0, 255, 255);
delay(30);
delay(30);
void faderFive()
delay(30);
delay(30);
void faderSix()
setColor(255, 127, 80);
for (int fadeValue = 80; fadeValue <=255; fadeValue += 5){
analogWrite(bluePin, fadeValue);
delay(30);
for (int fadeValue = 255; fadeValue >= 80; fadeValue -= 5){
delay(30);
void faderSeven()
setColor(128, 0, 0);
setColor(139, 0, 0);
setColor(165, 42, 42);
setColor(178, 34, 34);
setColor(220, 0, 0);
MoodLight.ino (5.11 KB)
