global variable for multiple objects?
i've created a couple objects:
  Button recBtn = Button(7);
  Button playBtn = Button(8);
What would need to be done to create a global variable shared by both objects? Make them subclasses rather than classes? Can anyone point me to an example?
Gabe
A good way to share variables between instances of a class in C++ is to make them static. For example:
class Button {
public:
    // blah blah blah...
private:
    int  fred;
    static int barney;
int Button::barney = 17;
In this contrived example, recBtn and playBtn each have their own, independent copy of “fred”, but they share a single copy of “barney”. Note that you must declare each static variable inside the class, and define them outside the class. Hope this helps.
  • Don
