I have a master esp8266 that sends data in a structure "dataPacket" to this slave esp8266.
when the slave receives an instruction it creates a local structure (packet) and calls method "dataReceived" but when I try to update global variables
bool openWindow;
bool closeWindow;
inside the function, using code
openWindow = packet.openWindow;
closeWindow = packet.closeWindow;
it fails to update. Any ideas why?
#include<ESP8266WiFi.h>
#include<espnow.h>
#define MY_NAME "SLAVE_BED_WINDOW"
//define global variables
bool openWindow;
bool closeWindow;
//define structures
struct __attribute__((packed)) dataPacket {
bool openWindow;
bool closeWindow;
//Define methods
void dataReceived(uint8_t *senderMac, uint8_t *data, uint8_t dataLength) {
char macStr[18];
dataPacket packet;
snprintf(macStr, sizeof(macStr), "%02x:%02x:%02x:%02x:%02x:%02x", senderMac[0], senderMac[1], senderMac[2], senderMac[3], senderMac[4], senderMac[5]);
Serial.print("Received data from: ");
Serial.println(macStr);
memcpy(&packet, data, sizeof(packet));
Serial.print("Sent Open Window: ");
Serial.println(packet.openWindow);
Serial.print("Sent Close Window: ");
Serial.println(packet.closeWindow);
Serial.print("Open Window: ");
Serial.println(openWindow);
Serial.print("Close Window: ");
Serial.println(closeWindow);
//Setup program
pinMode(D4, OUTPUT);
pinMode(D1, OUTPUT);
pinMode(2, OUTPUT);
pinMode(16, OUTPUT);
digitalWrite(2, LOW);
Serial.begin(9600); // initialize serial port
Serial.print("Initializing...");
Serial.println(MY_NAME);
Serial.print("My MAC address is: ");
Serial.println(WiFi.macAddress());
WiFi.mode(WIFI_STA);
WiFi.disconnect(); // we do not want to connect to a WiFi network
if(esp_now_init() != 0) {
Serial.println("ESP-NOW initialization failed");
return;
esp_now_register_recv_cb(dataReceived); // this function will get called once all data is sent
Serial.println("Initialized.");
//define program
if(openWindow == 1) {
digitalWrite(2, HIGH);
digitalWrite(16, LOW);
digitalWrite(D2, LOW);
Serial.println("opening window");
} else if(closeWindow == 1) {
digitalWrite(16, HIGH);
Serial.println("closing window");
//Serial.println("no change ");
