I am using global variables to hold the result of a comparison of an IR keypad button selection.
Within my get_key() function, the variables do not get changed according to the
if (irrecv.decode(&results))
Always true, set to 1, even when no key pressed.
Not sure why, if turning LED on and off WITHIN the function does work according to the same compare test.
[code]
#include <IRremote.h> // use the library for IR
const int receiver = 3; // pin 1 of IR receiver to Arduino digital pin 3
const int sounder = 2;
const int opto = 4;
const int mode = 5;
IRrecv irrecv(receiver); // create instance of 'irrecv'
decode_results results;
int array1[264];
int array2[264];
int key = 0;
int ok = 0;
int up = 0;
int down = 0;
//unsigned long last1 = millis();
pinMode(sounder, OUTPUT);digitalWrite(sounder, LOW);
pinMode(opto, INPUT_PULLUP);
pinMode(mode, INPUT_PULLUP);
irrecv.enableIRIn();
void beep()
digitalWrite(sounder,HIGH);delay(100);digitalWrite(sounder,LOW);
void get_key()
Serial.print (results.value);//debug
Serial.print ("\n");
if (results.value == 0xFF4AB5)key = 0;
if (results.value == 0xFF6897)key = 1;
if (results.value == 0xFF9867)key = 2;
if (results.value == 0xFFB04F)key = 3;
if (results.value == 0xFF02FD){ok = 1;} else {ok = 0;}
if (results.value == 0xFF629D){up = 1;} else {up = 0;}
if (results.value == 0xFFA857){down = 1;}else {down = 0;}
irrecv.resume();
int val = digitalRead(mode);
while (val = HIGH)
int val2 = digitalRead(opto);
while (val2 = LOW)
{delay(1000);}//temp reverse assume beam interrupted debug
//stop_motor()
for (int pointer = 0;pointer<264;pointer++)
ok = 0;up = 0;down = 0;
get_key();
array1[pointer] = key;
delay (300);
if (ok = 1)//debug test
Serial.print ("ok = 1");//debug
if (ok = 1)beep();
get_key();
if (up = 1)
Serial.print ("up = 1");//debug
array2[pointer] += array2[pointer];}//also echo to UART
if (down = 1)
Serial.print ("down = 1");//debug
array2[pointer] -= array2[pointer];}//also echo to UART
if (ok = 1){beep();delay(200);beep();}
Serial.print(array1[1]);//debug
Serial.print(array2[1]);
Serial.print("/n");
[/code]
irrx.ino (1.24 KB)
