Hi all.
this is my very first message in the community.
I quit C++ programming a while ago...
I am trying to implement a very simple routine, to control a servomotor pressing the button of the joystick.
basically I want to start and stop the motor by clicking the joystick button.
i made a routine to check the button and toggle a boolean if the button is pressed; I call the routine at every loop of both "for loops" and use the boolean to control the loops.
the behavoir is quite dodgy; I had to put a delay(10) in the routine and it's still not working properly.
This is my code (I omitted the includes and stuff):
static boolean domotor=true;
const int SW_pin = 2;
pinMode(SW_pin, INPUT);
digitalWrite(SW_pin, HIGH);
myservo.attach(9);
myservo.write(0);
void check(){
int pin = digitalRead(SW_pin);
if(pin==0) {
domotor=!domotor;
delay(10);
Serial.print(pin);Serial.print(" ");Serial.print(domotor?"TRUE":"FALSE");
Serial.print("\n");
check();
for (pos = 0; domotor && pos <= 180; pos += 1) {
myservo.write(pos);
delay(15);
check();
for (pos = 180; domotor && pos >= 0; pos -= 1) {
myservo.write(pos);
delay(15);
check();
Is it correct?
thanks a million
Marcello
