Below are the two files. In the function where i want to put the code in, i have writte down
"// MARKER" for you (second file). I cut off not important parts, cause the maximum allowed length here.
Thank you very much!
Main-File: ESP32-Cam-FaceRecognitionMQTT
WiFiClient espClient;
PubSubClient client(espClient);
void startCameraServer();
Serial.println("Init Cam");
// camera init
esp_err_t err = esp_camera_init(&config); //SBS esp_camera_init ist eine Funktion zur Initialisierung der Kamera (aus esp_camera.h). esp_err_t ist ein Datentyp für ESP-Errors
if (err != ESP_OK) {
Serial.printf("Camera init failed with error 0x%x", err);
return;
Serial.println("Start Wifi");
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
client.setServer(mqtt_server, 1883);
client.setCallback(callback);
if (!client.connected()) {
MyMQTTreconnect();
client.loop();
long now = millis();
if (now - lastMsg > 10000) {
lastMsg = now;
++value;
snprintf (msg, 50, "hello world #%ld", value);
Serial.print("Publish message: ");
Serial.println(msg);
client.publish("esp32/ichbinda", msg);
Second file "app_httpd.cpp"
static int run_face_recognition(dl_matrix3du_t *image_matrix, box_array_t *net_boxes){
dl_matrix3du_t *aligned_face = NULL;
int matched_id = 0;
aligned_face = dl_matrix3du_alloc(1, FACE_WIDTH, FACE_HEIGHT, 3);
if(!aligned_face){
Serial.println("Could not allocate face recognition buffer");
return matched_id;
if (align_face(net_boxes, image_matrix, aligned_face) == ESP_OK){
if (is_enrolling == 1){
//int8_t left_sample_face = enroll_face(&id_list, aligned_face);
int8_t left_sample_face = enroll_face_id_to_flash(&id_list, aligned_face); //SBS
if(left_sample_face == (ENROLL_CONFIRM_TIMES - 1)){
Serial.printf("Enrolling Face ID: %d\n", id_list.tail);
Serial.printf("Enrolling Face ID: %d sample %d\n", id_list.tail, ENROLL_CONFIRM_TIMES - left_sample_face);
rgb_printf(image_matrix, FACE_COLOR_CYAN, "ID[%u] Sample[%u]", id_list.tail, ENROLL_CONFIRM_TIMES - left_sample_face);
if (left_sample_face == 0){
is_enrolling = 0;
Serial.printf("Enrolled Face ID: %d\n", id_list.tail);
matched_id = recognize_face(&id_list, aligned_face);
if (matched_id >= 0) {
Serial.printf("Match Face ID: %u\n", matched_id);
rgb_printf(image_matrix, FACE_COLOR_GREEN, "Hello Subject %u", matched_id);
// MARKER
// Here i want to run code, publish MQTT for example:
// client.publish("esp32/ichbinda", msg);
// but it is not the realm of the object "client"
Serial.println("No Match Found");
rgb_print(image_matrix, FACE_COLOR_RED, "Intruder Alert!");
matched_id = -1;
Serial.println("Face Not Aligned");
//rgb_print(image_matrix, FACE_COLOR_YELLOW, "Human Detected");
dl_matrix3du_free(aligned_face);
return matched_id;
