Hello,
I am new to user to Arduino. I am currently creating a sketch for 5 air pollution sensors which will be used in a device with an Arduino Nano microcontroller, but am receiving the following error:
Global variables use 3082 bytes (150%) of dynamic memory, leaving -1034 bytes for local variables. Maximum is 2048 bytes.
Not enough memory
I would appreciate any tips on how to reduce the memory or if I should try using a Mega instead. The sketch is not yet complete. Thanks!
// MQ 131 libraries and definitions
#include <MQUnifiedsensor.h>
#define placa "Arduino UNO"
#define Voltage_Resolution 5
#define pin A0 //Analog input 0 of your arduino
#define type "MQ-131" //MQ131
#define ADC_Bit_Resolution 10 // For arduino UNO/MEGA/NANO
#define RatioMQ131CleanAir 15 //RS / R0 = 15 ppm
//#define calibration_button 13 //Pin to calibrate your sensor
MQUnifiedsensor MQ131(placa, Voltage_Resolution, ADC_Bit_Resolution, pin, type);
#define EXE_INTERVAL_131 500
unsigned long lastExecutedMillis_131 = 0; // vairable to save the last executed time for MQ 131
// PM2.5 libraries and variables
#define EXE_INTERVAL_25 100
unsigned long lastExecutedMillis_25 = 0; // vairable to save the last executed time for PM2.5 setup
#define EXE_INTERVAL_25_2 5000
unsigned long lastExecutedMillis_25_2 = 0; // vairable to save the last executed time for PM2.5 loop
#include <Tomoto_HM330X.h>
Tomoto_HM330X sensor;
// Tomoto_HM330X sensor(Wire1); // to use the alternative wire
void printValue(const char* label, int value) {
Serial.print(label);
Serial.print(": ");
Serial.println(value);
// Multichannel grove libraries and variables
#include <Wire.h>
#include "MutichannelGasSensor.h"
#define SENSOR_ADDR 0X04 // default to 0x04
#define PRE_HEAT_TIME 30 // pre-heat time, 10-30 minutes is recommended
#define EXE_INTERVAL_multi 1000
unsigned long lastExecutedMillis_multi = 0; // vairable to save the last executed time for multichannel sensor
// AM2320 libraries and variables
#include "AM232X.h"
AM232X AM2320;
#define EXE_INTERVAL_2320 2000
unsigned long lastExecutedMillis_2320 = 0; // vairable to save the last executed time for AM2320 setup
#define EXE_INTERVAL_2320_2 2000
unsigned long lastExecutedMillis_2320_2 = 0; // vairable to save the last executed time for AM2320 loop
// MQ 135 variables
#define EXE_INTERVAL_135 20
unsigned long lastExecutedMillis_135 = 0; // vairable to save the last executed time for MQ 135
// MQ 131 setup
//Init the serial port communication - to debug the library
Serial.begin(9600); //Init serial port
//Set math model to calculate the PPM concentration and the value of constants
MQ131.setRegressionMethod(1); //_PPM = a*ratio^b
MQ131.setA(23.943); MQ131.setB(-1.11); // Configurate the ecuation values to get O3 concentration
MQ131.init();
Serial.print("Calibrating please wait.");
float calcR0 = 0;
for (int i = 1; i <= 10; i ++)
MQ131.update(); // Update data, the arduino will be read the voltage on the analog pin
calcR0 += MQ131.calibrate(RatioMQ131CleanAir);
Serial.print(".");
MQ131.setR0(calcR0 / 10);
Serial.println(" done!.");
if (isinf(calcR0)) {
Serial.println("Warning: Conection issue founded, R0 is infite (Open circuit detected) please check your wiring and supply");
while (1);
if (calcR0 == 0) {
Serial.println("Warning: Conection issue founded, R0 is zero (Analog pin with short circuit to ground) please check your wiring and supply");
while (1);
/***************************** MQ CAlibration ********************************************/
MQ131.serialDebug(true);
// MQ 135 setup
// initialize serial communication at 9600 bits per second:
// PM2.5 setup
if (currentMillis - lastExecutedMillis_25 >= EXE_INTERVAL_25) {
lastExecutedMillis_25 = currentMillis; // save the last executed time
// Wire.begin(25, 21); // to specify the I2C pins
if (!sensor.begin()) {
Serial.println("Failed to initialize HM330X");
while (1)
Serial.println("HM330X initialized");
// Multichannel grove setup
if (currentMillis - lastExecutedMillis_multi >= EXE_INTERVAL_multi) {
lastExecutedMillis_multi = currentMillis; // save the last executed time
gas.begin(SENSOR_ADDR); //
Serial.println("power on, and pre-heat");
for (int i = 60 * PRE_HEAT_TIME; i >= 0; i--) {
Serial.print(i / 60);
Serial.print(":");
Serial.println(i % 60);
Serial.println("Begin to calibrate...");
gas.doCalibrate();
Serial.println("Calibration ok");
gas.display_eeprom();
// AM 2320 setup
if (currentMillis - lastExecutedMillis_2320 >= EXE_INTERVAL_2320) {
lastExecutedMillis_2320 = currentMillis; // save the last executed time
Serial.println(__FILE__);
Serial.print("LIBRARY VERSION: ");
Serial.println(AM232X_LIB_VERSION);
if (! AM2320.begin() )
Serial.println("Sensor not found");
while (1);
AM2320.wakeUp();
// sensor only returns one decimal.
Serial.println("Read:\t");
int status = AM2320.read();
switch (status)
case AM232X_OK:
Serial.println("OK");
default:
Serial.println(status);
Serial.print("Temperature:\t");
Serial.println(AM2320.getTemperature(), 1);
Serial.print(" Humidity:\t");
Serial.println(AM2320.getHumidity(), 1);
Serial.println("GET SENSOR INFO (experimental)");
Serial.print(" Model:\t");
Serial.println(AM2320.getModel());
Serial.print("Version:\t");
Serial.println(AM2320.getVersion());
Serial.print(" DevId:\t");
Serial.println(AM2320.getDeviceID());
Serial.println("GET REGISTERS (experimental)");
Serial.print(" Status:\t");
Serial.println(AM2320.getStatus());
Serial.print(" UserA:\t");
Serial.println(AM2320.getUserRegisterA());
Serial.print(" UserB:\t");
Serial.println(AM2320.getUserRegisterB());
Serial.println("SET REGISTERS (experimental)");
AM2320.setStatus(42);
Serial.print("Status 42 ==> ");
AM2320.setUserRegisterA(1234);
Serial.print("UserA 1234 ==> ");
AM2320.setUserRegisterB(5678);
Serial.print("UserB 5678 ==> ");
Serial.println("done...\n");
// MQ 131 loop
if (currentMillis - lastExecutedMillis_131 >= EXE_INTERVAL_131) {
lastExecutedMillis_131 = currentMillis; // save the last executed time
MQ131.readSensor(); // Sensor will read PPM concentration using the model and a and b values setted before or in the setup
MQ131.serialDebug(); // Will print the table on the serial port
// MQ 135 loop
if (currentMillis - lastExecutedMillis_135 >= EXE_INTERVAL_135) {
lastExecutedMillis_135 = currentMillis; // save the last executed time
// read the input on analog pin 1:
int sensorValue = analogRead(A1);
// print out the value you read:
Serial.println(sensorValue);
// PM2.5 loop
if (currentMillis - lastExecutedMillis_25_2 >= EXE_INTERVAL_25_2) {
lastExecutedMillis_25_2 = currentMillis; // save the last executed time
if (!sensor.readSensor()) {
Serial.println("Failed to read HM330X");
printValue("Sensor number", sensor.getSensorNumber());
Serial.println("Concentration based on CF=1 standard particlate matter (ug/m^3) --");
printValue("PM1.0", sensor.std.getPM1());
printValue("PM2.5", sensor.std.getPM2_5());
printValue("PM10", sensor.std.getPM10());
Serial.println("Concentration based on atmospheric environment (ug/m^3) --");
printValue("PM1.0", sensor.atm.getPM1());
printValue("PM2.5", sensor.atm.getPM2_5());
printValue("PM10", sensor.atm.getPM10());
// Maybe supported or not, depending on the sensor model
Serial.println("Number of particles with diameter of (/0.1L) --");
printValue(">=0.3um", sensor.count.get0_3());
printValue(">=0.5um", sensor.count.get0_5());
printValue(">=1.0um", sensor.count.get1());
printValue(">=2.5um", sensor.count.get2_5());
printValue(">=5.0um", sensor.count.get5());
printValue(">=10um", sensor.count.get10());
// AM 2320 loop
if (currentMillis - lastExecutedMillis_2320_2 >= EXE_INTERVAL_2320_2) {
lastExecutedMillis_2320_2 = currentMillis; // save the last executed time
switch (status)
case AM232X_OK:
default:
Serial.print("Temp:\t");
Serial.print("Hum:\t");
