GN-801 GPS change to 10hz
I am using a GN-801 gps module and by default it is using 1hz data collection rate, how can you change it to 10hz?
This is the GPS modul I am using
static const uint32_t GPSBaud = 9600;
SoftwareSerial ss(RXPin, TXPin);
  ss.begin(GPSBaud);
  ss.write("115200");
Is this the way to change the GPS modul frequency?
It does not say specifically, but it may be a Ublox M8 GPS.
If it is you will find the commands to change the update rate in the GPSs 'Protocol Specification' data sheet.
The baud rate is the speed of data transfer b/w the GPS & yr device.
Freq of data capture from the satellites is controlled by sending a command to the unit.
Explore with u-blox's u-centre software.
