Hi guys,
i need to pick up the signal from gnd from three sensors , how to do it. I am using arduino mega . The power supply of board where are the sensors is separate .
I have no idea how to do this.
Thank you very much
Hi guys,
Thank you very much
The sensors and the Arduino need a common GND to give a common point of reference for the measurement of the voltage level by the Arduino
The sensors and the Arduino should have a common GND connection, then you can sense the voltages on 3 separate Arduino pins
What type of sensors are they
Posting a schematic, not a frizzy picture with links to "Technical" information on the hardware devices will help us ensure you get a good answer.
Thank you very much.
Your diagram does not help.
You NEED to provide:
1: LINKS to the data sheets for the sensors
2: an explanation of what you hope to achieve. So eg if the sensors are switches you can place a resistor in the ground connection that will give a logic level signal the arduino can use.
