Gnuplot on Yun
I wanted to install gnuplot on the yun (on my virtual environment), so I tried ALL these commands over SSH:
 /opt/python/bin/pip install gnuplot
/opt/python/bin/pip install --allow-unverified gnuplot
/opt/python/bin/pip install --allow-external gnuplot
/opt/python/bin/pip install --allow-all-external gnuplot
/opt/python/bin/pip install --allow-unverified gnuplot --allow-all-external gnuplot
But the terminal only shows this....
Downloading/unpacking gnuplot
...and then SSH disconnects and the Yun reboots... there is also no log-file created.
My virtualenv is istalled on a 2GB SD (directory: /opt ), so disk space shouldn't be the problem...
EDIT: I know that I could simply install gnuplot on the Yuns internal memory (with opkg install gnuplot), but I want to install gnuplot on the SD....
gnuplot for python is "gnuplot-py"
cd /tmp
wget http://pkgs.fedoraproject.org/repo/pkgs/gnuplot-py/gnuplot-py-1.8.tar.gz/abd6f571e7aec68ae7db90a5217cd5b1/gnuplot-py-1.8.tar.gz
pip install gnuplot-py-1.8.tar.gz
 import numpy
ImportError: No module named numpy
gnuplot-py need numpy support, but AR9331 has no floating point support.
Makefile of numpy at Openwrt:
DEPENDS:=+python-mini @TARGET_x86||TARGET_olpc||TARGET_uml @BROKEN
Use gnuplot which does not require numpy as work around.
