If I open the code in a 'Examples' and test it, there is no problem.
The code I use may have been created with a different version.and this code is on desktop.
PS C:\Users\Tol\AppData\Local\Programs\Arduino IDE> & ".\Arduino IDE"
Arduino IDE 2.2.1
Checking for frontend application configuration customizations. Module path: C:\Users\Tol\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\electron-main.js, destination 'package.json': C:\Users\Tol\AppData\Local\Programs\Arduino IDE\resources\app\package.json
Setting 'theia.frontend.config.appVersion' application configuration value to: "2.2.1" (type of string)
Setting 'theia.frontend.config.cliVersion' application configuration value to: "0.34.0" (type of string)
Setting 'theia.frontend.config.buildDate' application configuration value to: "2023-08-31T14:35:44.802Z" (type of string)
Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{}},"defaultLocale":"","validatePreferencesSchema":false,"preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.2.1","cliVersion":"0.34.0","buildDate":"2023-08-31T14:35:44.802Z"}
Starting backend process. PID: 1892
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///c%3A/Users/Tol/.arduinoIDE'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2023-10-24T18:21:31.882Z root INFO Backend Object.initialize: 6.6 ms [Finished 0.699 s after backend start]
2023-10-24T18:21:31.883Z root INFO Backend Object.configure: 5.4 ms [Finished 0.699 s after backend start]
2023-10-24T18:21:31.883Z root INFO Backend a.onStart: 2.5 ms [Finished 0.699 s after backend start]
2023-10-24T18:21:31.884Z root INFO Backend a.configure: 0.4 ms [Finished 0.738 s after backend start]
2023-10-24T18:21:31.885Z root INFO Backend u.onStart: 0.3 ms [Finished 0.738 s after backend start]
2023-10-24T18:21:31.886Z root INFO Backend d.configure: 0.1 ms [Finished 0.738 s after backend start]
2023-10-24T18:21:31.887Z root INFO Backend d.initialize: 38.2 ms [Finished 0.738 s after backend start]
2023-10-24T18:21:31.888Z root INFO Backend c.onStart: 0.3 ms [Finished 0.738 s after backend start]
2023-10-24T18:21:31.888Z root INFO Backend s.configure: 1.7 ms [Finished 0.740 s after backend start]
2023-10-24T18:21:31.891Z config INFO >>> Initializing CLI configuration...
2023-10-24T18:21:31.891Z root INFO Backend c.initialize: 0.5 ms [Finished 0.740 s after backend start]
2023-10-24T18:21:31.891Z root INFO Backend P.onStart: 1.0 ms [Finished 0.741 s after backend start]
2023-10-24T18:21:31.893Z config INFO Loading CLI configuration from c:\Users\Tol\.arduinoIDE\arduino-cli.yaml...
2023-10-24T18:21:31.894Z daemon INFO Starting daemon from C:\Users\Tol\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2023-10-24T18:21:31.894Z root INFO Backend s.initialize: 0.5 ms [Finished 0.742 s after backend start]
2023-10-24T18:21:31.894Z root INFO Backend w.onStart: 1.7 ms [Finished 0.744 s after backend start]
2023-10-24T18:21:31.895Z root INFO Backend r.configure: 3.1 ms [Finished 0.744 s after backend start]
2023-10-24T18:21:31.895Z discovery-log INFO start
2023-10-24T18:21:31.895Z discovery-log INFO start new deferred
2023-10-24T18:21:31.895Z root INFO Backend d.initialize: 0.5 ms [Finished 0.745 s after backend start]
2023-10-24T18:21:31.896Z root INFO Backend y.onStart: 2.8 ms [Finished 0.747 s after backend start]
2023-10-24T18:21:31.896Z root INFO Backend r.configure: 2.7 ms [Finished 0.748 s after backend start]
2023-10-24T18:21:31.897Z root INFO Backend s.onStart: 0.7 ms [Finished 0.751 s after backend start]
2023-10-24T18:21:31.897Z root INFO Backend h.configure: 0.9 ms [Finished 0.751 s after backend start]
2023-10-24T18:21:31.898Z root INFO Backend a.configure: 0.8 ms [Finished 0.752 s after backend start]
2023-10-24T18:21:31.898Z root INFO Backend s.configure: 0.1 ms [Finished 0.753 s after backend start]
2023-10-24T18:21:31.899Z root INFO Backend l.configure: 0.2 ms [Finished 0.754 s after backend start]
2023-10-24T18:21:31.904Z root INFO Theia app listening on http://localhost:60374.
2023-10-24T18:21:31.905Z root INFO Finished starting backend application: 9.0 ms [Finished 0.760 s after backend start]
2023-10-24T18:21:31.913Z root WARN The local plugin referenced by local-dir:/c%3A/Users/Tol/.arduinoIDE/extensions does not exist.
2023-10-24T18:21:31.914Z root WARN The local plugin referenced by local-dir:/c%3A/Users/Tol/.arduinoIDE/plugins does not exist.
2023-10-24T18:21:31.917Z root WARN The local plugin referenced by local-dir:C:\Users\Tol\.arduinoIDE\plugins does not exist.
Restoring workspace roots: c:\Users\Tol\Desktop\HPR-Rocket-Flight-Computer-master\HPR-Rocket-Flight-Computer-master\Main Code\HPR_Rocket_Flight_PC_V4_6
isTempSketch: false. Input was c:\Users\Tol\Desktop\HPR-Rocket-Flight-Computer-master\HPR-Rocket-Flight-Computer-master\Main Code\HPR_Rocket_Flight_PC_V4_6\Bus_Mgmt.ino
2023-10-24T18:21:32.005Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":[]},"build_cache":{"compilations_before_purge":10,"ttl":"720h0m0s"},"daemon":{"port":"50051"},"directories":{"builtin":{"libraries":"C:\\Users\\Tol\\AppData\\Local\\Arduino15\\libraries"},"data":"c:\\Users\\Tol\\AppData\\Local\\Arduino15","downloads":"C:\\Users\\Tol\\AppData\\Local\\Arduino15\\staging","user":"c:\\Users\\Tol\\Documents\\Arduino"},"library":{"enable_unsafe_install":false},"locale":"en","logging":{"file":"","format":"text","level":"info"},"metrics":{"addr":":9090","enabled":true},"output":{"no_color":false},"sketch":{"always_export_binaries":false},"updater":{"enable_notification":true}}
2023-10-24T18:21:32.013Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2023-10-24T18:21:32.014Z config INFO Loaded the CLI configuration.
2023-10-24T18:21:32.039Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/Tol/AppData/Local/Arduino15","sketchDirUri":"file:///c%3A/Users/Tol/Documents/Arduino","additionalUrls":[],"network":"none","locale":"en"}
2023-10-24T18:21:32.041Z config INFO Validating the CLI configuration...
2023-10-24T18:21:32.045Z config INFO The CLI config is valid.
2023-10-24T18:21:32.054Z config INFO <<< Initialized the CLI configuration.
2023-10-24T18:21:32.093Z root INFO Resolve plugins list: 200.3 ms [Finished 0.949 s after backend start]
2023-10-24T18:21:32.230Z daemon INFO time="2023-10-24T21:21:32+03:00" level=info msg="Using config file: c:\\Users\\Tol\\.arduinoIDE\\arduino-cli.yaml"
time="2023-10-24T21:21:32+03:00" level=info msg="arduino-cli.exe version 0.34.0"
time="2023-10-24T21:21:32+03:00" level=info msg="Executing `arduino-cli daemon`"
Daemon is now listening on 127.0.0.1:60376
{"IP":"127.0.0.1","Port":"60376"}
2023-10-24T18:21:32.232Z daemon INFO Daemon is running.
2023-10-24T18:21:32.495Z daemon INFO time="2023-10-24T21:21:32+03:00" level=info msg="Checking signature" index="c:\\Users\\Tol\\AppData\\Local\\Arduino15\\package_index.json" signatureFile="c:\\Users\\Tol\\AppData\\Local\\Arduino15\\package_index.json.sig" trusted=true
time="2023-10-24T21:21:32+03:00" level=info msg="Loading hardware from: c:\\Users\\Tol\\AppData\\Local\\Arduino15\\packages"
time="2023-10-24T21:21:32+03:00" level=info msg="Loading package OpenCR from: C:\\Users\\Tol\\AppData\\Local\\Arduino15\\packages\\OpenCR\\hardware"
time="2023-10-24T21:21:32+03:00" level=info msg="Missing signature file" index="C:\\Users\\Tol\\AppData\\Local\\Arduino15\\packages\\OpenCR\\hardware\\OpenCR\\1.5.3\\installed.json"
time="2023-10-24T21:21:32+03:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2023-10-24T21:21:32+03:00" level=info msg="Loaded platform" platform="OpenCR:OpenCR@1.5.3"
time="2023-10-24T21:21:32+03:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\Tol\\AppData\\Local\\Arduino15\\packages\\OpenCR\\tools"
time="2023-10-24T21:21:32+03:00" level=info msg="Loading tools from dir: C:\\Users\\Tol\\AppData\\Local\\Arduino15\\packages\\OpenCR\\tools"
time="2023-10-24T21:21:32+03:00" level=info msg="Loaded tool" tool="OpenCR:opencr_gcc@5.4.0-2016q2"
time="2023-10-24T21:21:32+03:00" level=info msg="Loaded tool" tool="OpenCR:opencr_tools@1.0.0"
time="2023-10-24T21:21:32+03:00" level=info msg="Loading package arduino from: C:\\Users\\Tol\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware"
time="2023-10-24T21:21:32+03:00" level=info msg="Missing signature file" index="C:\\Users\\Tol\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\installed.json"
time="2023-10-24T21:21:32+03:00" level=info msg="Loaded platform" platform="arduino:avr@1.8.6"
time="2023-10-24T21:21:32+03:00" level=info msg="Missing signature file" index="C:\\Users\\Tol\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.8\\installed.json"
time="2023-10-24T21:21:32+03:00" level=info msg="Loaded platform" platform="arduino:megaavr@1.8.8"
time="2023-10-24T21:21:32+03:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\Tol\\AppData\\Local\\Arduino15\\packages\\arduino\\tools"
time="2023-10-24T21:21:32+03:00" level=info msg="Loading tools from dir: C:\\Users\\Tol\\AppData\\Local\\Arduino15\\packages\\arduino\\tools"
time="2023-10-24T21:21:32+03:00" level=info msg="Loaded tool" tool="arduino:arduinoOTA@1.3.0"
time="2023-10-24T21:21:32+03:00" level=info msg="Loaded tool" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino5"
time="2023-10-24T21:21:32+03:00" level=info msg="Loaded tool" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
time="2023-10-24T21:21:32+03:00" level=info msg="Loaded tool" tool="arduino:avrdude@6.3.0-arduino17"
time="2023-10-24T21:21:32+03:00" level=info msg="Loading package builtin from: C:\\Users\\Tol\\AppData\\Local\\Arduino15\\packages\\builtin"
time="2023-10-24T21:21:32+03:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\Tol\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
time="2023-10-24T21:21:32+03:00" level=info msg="Loading tools from dir: C:\\Users\\Tol\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
time="2023-10-24T21:21:32+03:00" level=info msg="Loaded tool" tool="builtin:ctags@5.8-arduino11"
time="2023-10-24T21:21:32+03:00" level=info msg="Loaded tool" tool="builtin:dfu-discovery@0.1.2"
time="2023-10-24T21:21:32+03:00" level=info msg="Loaded tool" tool="builtin:mdns-discovery@1.0.9"
time="2023-10-24T21:21:32+03:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.4.0"
time="2023-10-24T21:21:32+03:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.13.0"
time="2023-10-24T21:21:32+03:00" level=info msg="Loading package esp8266 from: C:\\Users\\Tol\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware"
time="2023-10-24T21:21:32+03:00" level=info msg="Loaded platform" platform="esp8266:esp8266@3.1.1"
time="2023-10-24T21:21:32+03:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\Tol\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools"
time="2023-10-24T21:21:32+03:00" level=info msg="Loading tools from dir: C:\\Users\\Tol\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools"
time="2023-10-24T21:21:32+03:00" level=info msg="Loaded tool" tool="esp8266:mklittlefs@3.1.0-gcc10.3-e5f9fec"
time="2023-10-24T21:21:32+03:00" level=info msg="Loaded tool" tool="esp8266:mkspiffs@3.1.0-gcc10.3-e5f9fec"
time="2023-10-24T21:21:32+03:00" level=info msg="Loaded tool" tool="esp8266:python3@3.7.2-post1"
time="2023-10-24T21:21:32+03:00" level=info msg="Loaded tool" tool="esp8266:xtensa-lx106-elf-gcc@3.1.0-gcc10.3-e5f9fec"
time="2023-10-24T21:21:32+03:00" level=info msg="Loading package pololu-a-star from: C:\\Users\\Tol\\AppData\\Local\\Arduino15\\packages\\pololu-a-star\\hardware"
time="2023-10-24T21:21:32+03:00" level=info msg="Loaded platform" platform="pololu-a-star:avr@5.1.0"
time="2023-10-24T21:21:32+03:00" level=info msg="Loading package teensy from: C:\\Users\\Tol\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware"
time="2023-10-24T21:21:32+03:00" level=info msg="Missing signature file" index="C:\\Users\\Tol\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.1\\installed.json"
time="2023-10-24T21:21:32+03:00" level=info msg="Adding monitor tool" protocol=teensy tool="teensy:teensy-monitor"
time="2023-10-24T21:21:32+03:00" level=info msg="Loaded platform" platform="teensy:avr@1.58.1"
time="2023-10-24T21:21:32+03:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\Tol\\AppData\\Local\\Arduino15\\packages\\teensy\\tools"
time="2023-10-24T21:21:32+03:00" level=info msg="Loading tools from dir: C:\\Users\\Tol\\AppData\\Local\\Arduino15\\packages\\teensy\\tools"
time="2023-10-24T21:21:32+03:00" level=info msg="Loaded tool" tool="teensy:teensy-compile@11.3.1"
time="2023-10-24T21:21:32+03:00" level=info msg="Loaded tool" tool="teensy:teensy-discovery@1.58.0"
time="2023-10-24T21:21:32+03:00" level=info msg="Loaded tool" tool="teensy:teensy-monitor@1.58.0"
time="2023-10-24T21:21:32+03:00" level=info msg="Loaded tool" tool="teensy:teensy-tools@1.58.0"
2023-10-24T18:21:32.505Z daemon INFO time="2023-10-24T21:21:32+03:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Tol\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries" location=platform
2023-10-24T18:21:32.511Z daemon INFO time="2023-10-24T21:21:32+03:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Tol\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.8\\libraries" location=platform
2023-10-24T18:21:32.521Z daemon INFO time="2023-10-24T21:21:32+03:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Tol\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.1\\libraries" location=platform
2023-10-24T18:21:32.674Z daemon INFO time="2023-10-24T21:21:32+03:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Tol\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.1\\libraries" location=platform
time="2023-10-24T21:21:32+03:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Tol\\AppData\\Local\\Arduino15\\packages\\OpenCR\\hardware\\OpenCR\\1.5.3\\libraries" location=platform
time="2023-10-24T21:21:32+03:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Tol\\AppData\\Local\\Arduino15\\packages\\pololu-a-star\\hardware\\avr\\5.1.0\\libraries" location=platform
time="2023-10-24T21:21:32+03:00" level=info msg="Loading libraries index file" index="c:\\Users\\Tol\\AppData\\Local\\Arduino15\\library_index.json"
2023-10-24T18:21:33.129Z daemon INFO time="2023-10-24T21:21:33+03:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Tol\\AppData\\Local\\Arduino15\\libraries" location=ide
time="2023-10-24T21:21:33+03:00" level=info msg="Adding libraries dir" dir="c:\\Users\\Tol\\Documents\\Arduino\\libraries" location=user
2023-10-24T18:21:34.180Z root INFO Deploy plugins list: 200.3 ms [Finished 3.036 s after backend start]
Opening channel for service path '/services/electron-window'.
2023-10-24T18:21:34.917Z discovery-log INFO start request start watch
2023-10-24T18:21:34.917Z discovery-log INFO start requested start watch
2023-10-24T18:21:34.919Z discovery-log INFO start resolved watching
2023-10-24T18:21:34.924Z daemon INFO time="2023-10-24T21:21:34+03:00" level=info msg="starting discovery builtin:serial-discovery process"
2023-10-24T18:21:34.925Z daemon INFO time="2023-10-24T21:21:34+03:00" level=info msg="starting discovery builtin:mdns-discovery process"
2023-10-24T18:21:34.931Z daemon INFO time="2023-10-24T21:21:34+03:00" level=info msg="starting discovery teensy:teensy-discovery process"
Opening channel for service path '/services/ide-updater'.
2023-10-24T18:21:34.948Z daemon INFO time="2023-10-24T21:21:34+03:00" level=info msg="started discovery builtin:serial-discovery process"
time="2023-10-24T21:21:34+03:00" level=info msg="sending command HELLO 1 \"arduino-cli 0.34.0\" to discovery builtin:serial-discovery"
2023-10-24T18:21:34.951Z daemon INFO time="2023-10-24T21:21:34+03:00" level=info msg="started discovery builtin:mdns-discovery process"
time="2023-10-24T21:21:34+03:00" level=info msg="sending command HELLO 1 \"arduino-cli 0.34.0\" to discovery builtin:mdns-discovery"
2023-10-24T18:21:34.952Z daemon INFO time="2023-10-24T21:21:34+03:00" level=info msg="started discovery teensy:teensy-discovery process"
2023-10-24T18:21:34.955Z daemon INFO time="2023-10-24T21:21:34+03:00" level=info msg="sending command HELLO 1 \"arduino-cli 0.34.0\" to discovery teensy:teensy-discovery"
2023-10-24T18:21:34.977Z daemon INFO time="2023-10-24T21:21:34+03:00" level=info msg="from discovery teensy:teensy-discovery received message type: hello, message: OK, protocol version: 1"
2023-10-24T18:21:34.978Z daemon INFO time="2023-10-24T21:21:34+03:00" level=info msg="sending command START_SYNC to discovery teensy:teensy-discovery"
2023-10-24T18:21:34.983Z daemon INFO time="2023-10-24T21:21:34+03:00" level=info msg="from discovery teensy:teensy-discovery received message type: start_sync, message: OK"
2023-10-24T18:21:34.985Z daemon INFO time="2023-10-24T21:21:34+03:00" level=info msg="from discovery builtin:serial-discovery received message type: hello, message: OK, protocol version: 1"
2023-10-24T18:21:34.986Z daemon INFO time="2023-10-24T21:21:34+03:00" level=info msg="sending command START_SYNC to discovery builtin:serial-discovery"
2023-10-24T18:21:34.990Z daemon INFO time="2023-10-24T21:21:34+03:00" level=info msg="from discovery builtin:mdns-discovery received message type: hello, message: OK, protocol version: 1"
time="2023-10-24T21:21:34+03:00" level=info msg="sending command START_SYNC to discovery builtin:mdns-discovery"
2023-10-24T18:21:34.993Z daemon INFO time="2023-10-24T21:21:34+03:00" level=info msg="from discovery builtin:serial-discovery received message type: start_sync, message: OK"
2023-10-24T18:21:35.003Z daemon INFO time="2023-10-24T21:21:35+03:00" level=info msg="from discovery builtin:mdns-discovery received message type: start_sync, message: OK"
2023-10-24T18:21:35.519Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 503.7 ms [Finished 3.521 s after frontend start]
2023-10-24T18:21:35.534Z root WARN A command editor.action.toggleStickyScroll is already registered.
2023-10-24T18:21:35.555Z sketches-service WARN Warning! The request sketch path was different than the response sketch path from the CLI. This could be a potential bug. Request: <c:\Users\Tol\Desktop\HPR-Rocket-Flight-Computer-master\HPR-Rocket-Flight-Computer-master\Main Code\HPR_Rocket_Flight_PC_V4_6\Bus_Mgmt.ino>, response: <c:\Users\Tol\Desktop\HPR-Rocket-Flight-Computer-master\HPR-Rocket-Flight-Computer-master\Main Code\HPR_Rocket_Flight_PC_V4_6>.
2023-10-24T18:21:36.112Z root INFO Start frontend contributions: 1049.1 ms [Finished 3.886 s after frontend start]
2023-10-24T18:21:36.115Z root INFO Changed application state from 'init' to 'started_contributions'.
2023-10-24T18:21:36.116Z root INFO Changed application state from 'started_contributions' to 'attached_shell'.
2023-10-24T18:21:36.117Z root INFO >>> Restoring the layout state...
2023-10-24T18:21:36.120Z root INFO ------- SERIALIZED LAYOUT DATA -------
2023-10-24T18:21:36.129Z root INFO {"version":5,"mainPanel":{"main":{"type":"tab-area","widgets":[{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///c%3A/Users/Tol/Desktop/HPR-Rocket-Flight-Computer-master/HPR-Rocket-Flight-Computer-master/Main%20Code/HPR_Rocket_Flight_PC_V4_6/HPR_Rocket_Flight_PC_V4_6.ino"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":1738,\"column\":15},\"position\":{\"lineNumber\":1738,\"column\":15}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":1728,\"column\":1},\"firstPositionDeltaTop\":-17},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":2346,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///c%3A/Users/Tol/Desktop/HPR-Rocket-Flight-Computer-master/HPR-Rocket-Flight-Computer-master/Main%20Code/HPR_Rocket_Flight_PC_V4_6/Bus_Mgmt.ino"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":31,\"column\":40},\"position\":{\"lineNumber\":31,\"column\":40}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":67,\"column\":1},\"firstPositionDeltaTop\":-13},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":352,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///c%3A/Users/Tol/Desktop/HPR-Rocket-Flight-Computer-master/HPR-Rocket-Flight-Computer-master/Main%20Code/HPR_Rocket_Flight_PC_V4_6/Calibration.ino"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":1,\"column\":1},\"position\":{\"lineNumber\":1,\"column\":1}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":7,\"column\":1},\"firstPositionDeltaTop\":-3},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":900,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///c%3A/Users/Tol/Desktop/HPR-Rocket-Flight-Computer-master/HPR-Rocket-Flight-Computer-master/Main%20Code/HPR_Rocket_Flight_PC_V4_6/Event_Logic.ino"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":11,\"column\":15},\"position\":{\"lineNumber\":11,\"column\":15}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":1,\"column\":1},\"firstPositionDeltaTop\":0},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":327,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///c%3A/Users/Tol/Desktop/HPR-Rocket-Flight-Computer-master/HPR-Rocket-Flight-Computer-master/Main%20Code/HPR_Rocket_Flight_PC_V4_6/GPS_Config.ino"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":160,\"column\":52},\"position\":{\"lineNumber\":160,\"column\":52}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":139,\"column\":1},\"firstPositionDeltaTop\":-6},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":292,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///c%3A/Users/Tol/Desktop/HPR-Rocket-Flight-Computer-master/HPR-Rocket-Flight-Computer-master/Main%20Code/HPR_Rocket_Flight_PC_V4_6/Infilght_Recover.ino"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":1,\"column\":1},\"position\":{\"lineNumber\":1,\"column\":1}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":1,\"column\":1},\"firstPositionDeltaTop\":0},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":467,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///c%3A/Users/Tol/Desktop/HPR-Rocket-Flight-Computer-master/HPR-Rocket-Flight-Computer-master/Main%20Code/HPR_Rocket_Flight_PC_V4_6/Rotation.ino"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":1,\"column\":1},\"position\":{\"lineNumber\":1,\"column\":1}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":1,\"column\":1},\"firstPositionDeltaTop\":0},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":553,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///c%3A/Users/Tol/Desktop/HPR-Rocket-Flight-Computer-master/HPR-Rocket-Flight-Computer-master/Main%20Code/HPR_Rocket_Flight_PC_V4_6/SD.ino"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":1,\"column\":1},\"position\":{\"lineNumber\":1,\"column\":1}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":1,\"column\":1},\"firstPositionDeltaTop\":0},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":683,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///c%3A/Users/Tol/Desktop/HPR-Rocket-Flight-Computer-master/HPR-Rocket-Flight-Computer-master/Main%20Code/HPR_Rocket_Flight_PC_V4_6/Sensor_Drivers.ino"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":863,\"column\":46},\"position\":{\"lineNumber\":863,\"column\":46}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":852,\"column\":1},\"firstPositionDeltaTop\":-18},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":2281,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///c%3A/Users/Tol/Desktop/HPR-Rocket-Flight-Computer-master/HPR-Rocket-Flight-Computer-master/Main%20Code/HPR_Rocket_Flight_PC_V4_6/Speed_Trig.ino"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":1,\"column\":1},\"position\":{\"lineNumber\":1,\"column\":1}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":1,\"column\":1},\"firstPositionDeltaTop\":0},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":625,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///c%3A/Users/Tol/Desktop/HPR-Rocket-Flight-Computer-master/HPR-Rocket-Flight-Computer-master/Main%20Code/HPR_Rocket_Flight_PC_V4_6/Telemetry.ino"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":true,\"selectionStart\":{\"lineNumber\":4,\"column\":22},\"position\":{\"lineNumber\":4,\"column\":24}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":194,\"column\":1},\"firstPositionDeltaTop\":0},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":728,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"}],"currentIndex":0}},"mainPanelPinned":[false,false,false,false,false,false,false,false,false,false,false],"bottomPanel":{"config":{"main":{"type":"tab-area","widgets":[{"constructionOptions":{"factoryId":"outputView"},"innerWidgetState":"{\"locked\":false}"}],"currentIndex":0}},"pinned":[false],"size":112,"expanded":true},"leftPanel":{"type":"sidepanel","items":[{"widget":{"constructionOptions":{"factoryId":"arduino-sketchbook-widget"}},"rank":1,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"boards-list-widget"}},"rank":2,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"library-list-widget"}},"rank":3,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"debug"},"innerWidgetState":"{\"parts\":[{\"partId\":\"debug:threads:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:threads\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:frames:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:frames\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:variables:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:variables\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:watch:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:watch\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:breakpoints:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:breakpoints\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"plugin-view:cortex-debug.peripherals\",\"collapsed\":true,\"hidden\":true,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"plugin-view\",\"options\":{\"id\":\"plugin-view:cortex-debug.peripherals\",\"viewId\":\"cortex-debug.peripherals\"}},\"innerWidgetState\":\"{\\\"label\\\":\\\"Cortex Peripherals\\\",\\\"widgets\\\":[],\\\"suppressUpdateViewVisibility\\\":false,\\\"currentViewContainerId\\\":\\\"debug\\\"}\"}},{\"partId\":\"plugin-view:cortex-debug.registers\",\"collapsed\":true,\"hidden\":true,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"plugin-view\",\"options\":{\"id\":\"plugin-view:cortex-debug.registers\",\"viewId\":\"cortex-debug.registers\"}},\"innerWidgetState\":\"{\\\"label\\\":\\\"Cortex Registers\\\",\\\"widgets\\\":[],\\\"suppressUpdateViewVisibility\\\":false,\\\"currentViewContainerId\\\":\\\"debug\\\"}\"}}],\"title\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}}"},"rank":4,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"search-view-container"},"innerWidgetState":"{\"parts\":[{\"partId\":\"search-in-workspace\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"search-view-container\",\"originalContainerTitle\":{\"label\":\"Search\",\"iconClass\":\"codicon codicon-search\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"search-in-workspace\"},\"innerWidgetState\":\"{\\\"matchCaseState\\\":{\\\"className\\\":\\\"codicon codicon-case-sensitive\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Match Case\\\"},\\\"wholeWordState\\\":{\\\"className\\\":\\\"codicon codicon-whole-word\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Match Whole Word\\\"},\\\"regExpState\\\":{\\\"className\\\":\\\"codicon codicon-regex\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Use Regular Expression\\\"},\\\"includeIgnoredState\\\":{\\\"className\\\":\\\"codicon codicon-eye\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Include Ignored Files\\\"},\\\"showSearchDetails\\\":false,\\\"searchInWorkspaceOptions\\\":{\\\"matchCase\\\":false,\\\"matchWholeWord\\\":false,\\\"useRegExp\\\":false,\\\"includeIgnored\\\":false,\\\"include\\\":[],\\\"exclude\\\":[],\\\"maxResults\\\":2000},\\\"searchTerm\\\":\\\"\\\",\\\"replaceTerm\\\":\\\"\\\",\\\"showReplaceField\\\":false,\\\"searchHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"replaceHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"includeHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"excludeHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0}}\"}}],\"title\":{\"label\":\"Search\",\"iconClass\":\"fa fa-arduino-search\",\"closeable\":true}}"},"rank":5,"expanded":false,"pinned":false}],"size":268},"rightPanel":{"type":"sidepanel","items":[]},"activeWidgetId":"code-editor-opener:file:///c%3A/Users/Tol/Desktop/HPR-Rocket-Flight-Computer-master/HPR-Rocket-Flight-Computer-master/Main%20Code/HPR_Rocket_Flight_PC_V4_6/HPR_Rocket_Flight_PC_V4_6.ino:0"}
2023-10-24T18:21:36.149Z root INFO ------- END SERIALIZED LAYOUT DATA -------
2023-10-24T18:21:36.230Z root INFO [5197b74b-895b-4b0d-a87e-8137a5901039] Waiting for backend deployment: 382.9 ms [Finished 4.261 s after frontend start]
2023-10-24T18:21:37.054Z root INFO [hosted-plugin: 9436] PLUGIN_HOST(9436) starting instance
2023-10-24T18:21:37.736Z root INFO [5197b74b-895b-4b0d-a87e-8137a5901039] Sync of 23 plugins: 1509.7 ms [Finished 5.771 s after frontend start]
2023-10-24T18:21:38.752Z root INFO <<< The layout has been successfully restored.
2023-10-24T18:21:39.494Z root INFO Initialize the workbench layout: 2842.2 ms [Finished 6.787 s after frontend start]
2023-10-24T18:21:39.497Z root INFO Changed application state from 'attached_shell' to 'initialized_layout'.
2023-10-24T18:21:39.499Z root INFO [5197b74b-895b-4b0d-a87e-8137a5901039] Loading plugin contributions
2023-10-24T18:21:39.499Z root INFO [5197b74b-895b-4b0d-a87e-8137a5901039] Load contributions of 23 plugins: 737.0 ms [Finished 7.527 s after frontend start]
2023-10-24T18:21:39.581Z root WARN 'cpp' language is remapped from 'source.cpp.embedded.macro' to 'source.cpp' scope
2023-10-24T18:21:39.582Z root WARN a registered grammar configuration for 'cpp' language is overridden
2023-10-24T18:21:41.214Z root INFO Frontend application start: 5737.4 ms [Finished 10.070 s after backend start]
2023-10-24T18:21:41.245Z root INFO Replace loading indicator with ready workbench UI (animation): 1179.6 ms [Finished 8.711 s after frontend start]
2023-10-24T18:21:41.245Z root INFO Changed application state from 'initialized_layout' to 'ready'.
2023-10-24T18:21:41.247Z root WARN Linked preference "workbench.colorCustomizations" not found. Source: "editor.bracketPairColorization.enabled"
2023-10-24T18:21:41.836Z root ERROR [hosted-plugin: 9436] Conflict in settings file Default: Ignoring cortex-debug.armToolchainPath.linux as cortex-debug.armToolchainPath is null
2023-10-24T18:21:41.837Z root ERROR [hosted-plugin: 9436] Conflict in settings file Default: Ignoring cortex-debug.armToolchainPath.osx as cortex-debug.armToolchainPath is null
Conflict in settings file Default: Ignoring cortex-debug.armToolchainPath.windows as cortex-debug.armToolchainPath is null
Conflict in settings file Default: Ignoring cortex-debug.JLinkGDBServerPath.linux as cortex-debug.JLinkGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.JLinkGDBServerPath.osx as cortex-debug.JLinkGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.JLinkGDBServerPath.windows as cortex-debug.JLinkGDBServerPath is null
2023-10-24T18:21:41.839Z root ERROR [hosted-plugin: 9436] Conflict in settings file Default: Ignoring cortex-debug.openocdPath.linux as cortex-debug.openocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.openocdPath.osx as cortex-debug.openocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.openocdPath.windows as cortex-debug.openocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.pyocdPath.linux as cortex-debug.pyocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.pyocdPath.osx as cortex-debug.pyocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.pyocdPath.windows as cortex-debug.pyocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.PEGDBServerPath.linux as cortex-debug.PEGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.PEGDBServerPath.osx as cortex-debug.PEGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.PEGDBServerPath.windows as cortex-debug.PEGDBServerPath is nullConflict in settings file Default: Ignoring cortex-debug.stutilPath.linux as cortex-debug.stutilPath is null
Conflict in settings file Default: Ignoring cortex-debug.stutilPath.osx as cortex-debug.stutilPath is null
Conflict in settings file Default: Ignoring cortex-debug.stutilPath.windows as cortex-debug.stutilPath is null
Conflict in settings file Default: Ignoring cortex-debug.stlinkPath.linux as cortex-debug.stlinkPath is null
Conflict in settings file Default: Ignoring cortex-debug.stlinkPath.osx as cortex-debug.stlinkPath is null
Conflict in settings file Default: Ignoring cortex-debug.stlinkPath.windows as cortex-debug.stlinkPath is null
Conflict in settings file Default: Ignoring cortex-debug.stm32cubeprogrammer.linux as cortex-debug.stm32cubeprogrammer is null
Conflict in settings file Default: Ignoring cortex-debug.stm32cubeprogrammer.osx as cortex-debug.stm32cubeprogrammer is null
Conflict in settings file Default: Ignoring cortex-debug.stm32cubeprogrammer.windows as cortex-debug.stm32cubeprogrammer is null
2023-10-24T18:21:41.866Z root INFO [hosted-plugin: 9436] PLUGIN_HOST(9436): PluginManagerExtImpl/init()
2023-10-24T18:21:41.870Z root INFO [hosted-plugin: 9436] PLUGIN_HOST(9436): initializing(vscode-arduino-api@0.1.2 with C:\Users\Tol\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2023-10-24T18:21:41.965Z root INFO [hosted-plugin: 9436] PLUGIN_HOST(9436): initializing(cortex-debug@1.5.1 with C:\Users\Tol\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2023-10-24T18:21:41.966Z root INFO [hosted-plugin: 9436] Debugger contribution has been registered: cortex-debug
2023-10-24T18:21:41.968Z root INFO [hosted-plugin: 9436] PLUGIN_HOST(9436): initializing(vscode-arduino-tools@0.0.2-beta.8 with C:\Users\Tol\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2023-10-24T18:21:41.969Z root INFO [hosted-plugin: 9436] PLUGIN_HOST(9436): initializing(cpp@1.52.1 with C:\Users\Tol\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2023-10-24T18:21:41.971Z root INFO [hosted-plugin: 9436] PLUGIN_HOST(9436): initializing(json@1.46.1 with C:\Users\Tol\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2023-10-24T18:21:41.972Z root INFO [hosted-plugin: 9436] PLUGIN_HOST(9436): initializing(json-language-features@1.46.1 with C:\Users\Tol\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2023-10-24T18:21:41.974Z root INFO [hosted-plugin: 9436] PLUGIN_HOST(9436): initializing(vscode-language-pack-bg@1.48.3 with C:\Users\Tol\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2023-10-24T18:21:41.977Z root INFO [hosted-plugin: 9436] PLUGIN_HOST(9436): initializing(vscode-language-pack-cs@1.78.0 with C:\Users\Tol\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2023-10-24T18:21:41.979Z root INFO [hosted-plugin: 9436] PLUGIN_HOST(9436): initializing(vscode-language-pack-de@1.78.0 with C:\Users\Tol\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2023-10-24T18:21:41.980Z root INFO [hosted-plugin: 9436] PLUGIN_HOST(9436): initializing(vscode-language-pack-es@1.78.0 with C:\Users\Tol\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2023-10-24T18:21:41.982Z root INFO [hosted-plugin: 9436] PLUGIN_HOST(9436): initializing(vscode-language-pack-fr@1.78.0 with C:\Users\Tol\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2023-10-24T18:21:41.987Z root INFO [hosted-plugin: 9436] PLUGIN_HOST(9436): initializing(vscode-language-pack-hu@1.48.3 with C:\Users\Tol\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2023-10-24T18:21:41.989Z root INFO [hosted-plugin: 9436] PLUGIN_HOST(9436): initializing(vscode-language-pack-it@1.78.0 with C:\Users\Tol\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2023-10-24T18:21:41.991Z root INFO [hosted-plugin: 9436] PLUGIN_HOST(9436): initializing(vscode-language-pack-ja@1.78.0 with C:\Users\Tol\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2023-10-24T18:21:41.993Z root INFO [hosted-plugin: 9436] PLUGIN_HOST(9436): initializing(vscode-language-pack-ko@1.78.0 with C:\Users\Tol\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2023-10-24T18:21:41.994Z root INFO [hosted-plugin: 9436] PLUGIN_HOST(9436): initializing(vscode-language-pack-nl@1.48.3 with C:\Users\Tol\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2023-10-24T18:21:41.995Z root INFO [hosted-plugin: 9436] PLUGIN_HOST(9436): initializing(vscode-language-pack-pl@1.78.0 with C:\Users\Tol\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2023-10-24T18:21:41.998Z root INFO [hosted-plugin: 9436] PLUGIN_HOST(9436): initializing(vscode-language-pack-pt-BR@1.78.0 with C:\Users\Tol\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
PLUGIN_HOST(9436): initializing(vscode-language-pack-ru@1.78.0 with C:\Users\Tol\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
PLUGIN_HOST(9436): initializing(vscode-language-pack-tr@1.78.0 with C:\Users\Tol\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2023-10-24T18:21:42.001Z root INFO [hosted-plugin: 9436] PLUGIN_HOST(9436): initializing(vscode-language-pack-uk@1.48.3 with C:\Users\Tol\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
PLUGIN_HOST(9436): initializing(vscode-language-pack-zh-hans@1.78.0 with C:\Users\Tol\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
PLUGIN_HOST(9436): initializing(vscode-language-pack-zh-hant@1.78.0 with C:\Users\Tol\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2023-10-24T18:21:42.027Z root INFO [hosted-plugin: 9436] PLUGIN_HOST(9436): PluginManagerExtImpl/loadPlugin(C:\Users\Tol\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-arduino-api\extension\dist\extension.js)
2023-10-24T18:21:42.043Z root INFO [hosted-plugin: 9436] PLUGIN_HOST(9436): PluginManagerExtImpl/loadPlugin(C:\Users\Tol\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\jsonMain)
2023-10-24T18:21:42.402Z root INFO [hosted-plugin: 9436] PLUGIN_HOST(9436): PluginManagerExtImpl/loadPlugin(C:\Users\Tol\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-arduino-tools\extension\dist\bundle)
2023-10-24T18:21:42.492Z root INFO [5197b74b-895b-4b0d-a87e-8137a5901039] Starting plugins.
2023-10-24T18:21:42.503Z root INFO [hosted-plugin: 9436] PLUGIN_HOST(9436): PluginManagerExtImpl/loadPlugin(C:\Users\Tol\AppData\Local\Programs\Arduino IDE\resources\app\plugins\cortex-debug\extension\dist\extension.js)
2023-10-24T18:21:42.565Z root INFO [hosted-plugin: 9436] Debug configuration provider has been registered: cortex-debug, trigger: 1
2023-10-24T18:21:42.576Z root INFO [hosted-plugin: 9436] GDB server console created
2023-10-24T18:21:42.592Z root INFO [5197b74b-895b-4b0d-a87e-8137a5901039] Start of 23 plugins: 3085.7 ms [Finished 10.624 s after frontend start]
2023-10-24T18:21:42.598Z daemon INFO time="2023-10-24T21:21:42+03:00" level=info msg="Required tool" tool="teensy:teensy-compile@11.3.1"
time="2023-10-24T21:21:42+03:00" level=info msg="Required tool" tool="teensy:teensy-tools@1.58.0"
2023-10-24T18:21:42.626Z daemon INFO time="2023-10-24T21:21:42+03:00" level=info msg="Required tool" tool="teensy:teensy-compile@11.3.1"
2023-10-24T18:21:42.635Z root INFO Starting language server: teensy:avr:teensy41:usb=serial,speed=600,opt=o2std,keys=en-us
2023-10-24T18:21:42.787Z daemon INFO time="2023-10-24T21:21:42+03:00" level=info msg="Required tool" tool="teensy:teensy-compile@11.3.1"
2023-10-24T18:21:42.814Z daemon INFO time="2023-10-24T21:21:42+03:00" level=info msg="Required tool" tool="teensy:teensy-compile@11.3.1"
2023-10-24T18:21:43.090Z daemon INFO time="2023-10-24T21:21:43+03:00" level=info msg="Required tool" tool="teensy:teensy-compile@11.3.1"
time="2023-10-24T21:21:43+03:00" level=info msg="Required tool" tool="teensy:teensy-tools@1.58.0"
2023-10-24T18:21:43.093Z daemon INFO time="2023-10-24T21:21:43+03:00" level=info msg="Required tool" tool="teensy:teensy-compile@11.3.1"
2023-10-24T18:21:43.119Z daemon INFO time="2023-10-24T21:21:43+03:00" level=info msg="Required tool" tool="teensy:teensy-compile@11.3.1"
2023-10-24T18:21:43.121Z daemon INFO time="2023-10-24T21:21:43+03:00" level=info msg="Required tool" tool="teensy:teensy-tools@1.58.0"
2023-10-24T18:21:43.124Z daemon INFO time="2023-10-24T21:21:43+03:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Tol\\AppData\\Local\\Arduino15\\libraries" location=ide
2023-10-24T18:21:43.126Z daemon INFO time="2023-10-24T21:21:43+03:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Tol\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.1\\libraries" location=platform
2023-10-24T18:21:43.127Z daemon INFO time="2023-10-24T21:21:43+03:00" level=info msg="Adding libraries dir" dir="c:\\Users\\Tol\\Documents\\Arduino\\libraries" location=user
2023-10-24T18:21:43.197Z fwuploader ERROR Error: Process exited with exit code: 1
at ChildProcess.<anonymous> (C:\Users\Tol\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:603385)
at ChildProcess.emit (node:events:513:28)
at ChildProcess._handle.onexit (node:internal/child_process:291:12)
2023-10-24T18:21:43.198Z root ERROR Request updatableBoards failed with error: Process exited with exit code: 1 Error: Process exited with exit code: 1
2023-10-24T18:21:44.255Z daemon INFO time="2023-10-24T21:21:44+03:00" level=info msg="Resolving include EEPROM.h for arch avr"
2023-10-24T18:21:44.256Z daemon INFO time="2023-10-24T21:21:44+03:00" level=info msg=" found better lib" lib=EEPROM prio=6A6
2023-10-24T18:21:44.462Z daemon INFO time="2023-10-24T21:21:44+03:00" level=info msg="Resolving include TinyGPS++.h for arch avr"
time="2023-10-24T21:21:44+03:00" level=info msg=" found better lib" lib=TinyGPSPlus prio=3E8
2023-10-24T18:21:44.683Z daemon INFO time="2023-10-24T21:21:44+03:00" level=info msg="Resolving include PWMServo.h for arch avr"
time="2023-10-24T21:21:44+03:00" level=info msg=" found better lib" lib=PWMServo prio=6A6
2023-10-24T18:21:44.889Z daemon INFO time="2023-10-24T21:21:44+03:00" level=info msg="Resolving include SPI.h for arch avr"
time="2023-10-24T21:21:44+03:00" level=info msg=" found better lib" lib=SPI prio=6A6
2023-10-24T18:21:45.105Z daemon INFO time="2023-10-24T21:21:45+03:00" level=info msg="Resolving include Wire.h for arch avr"
time="2023-10-24T21:21:45+03:00" level=info msg=" found better lib" lib=Wire prio=6A6
2023-10-24T18:21:45.335Z daemon INFO time="2023-10-24T21:21:45+03:00" level=info msg="Resolving include Adafruit_GPS.h for arch avr"
time="2023-10-24T21:21:45+03:00" level=info msg=" found better lib" lib="Adafruit GPS Library" prio=517
2023-10-24T18:21:45.575Z daemon INFO time="2023-10-24T21:21:45+03:00" level=info msg="Resolving include SD.h for arch avr"
time="2023-10-24T21:21:45+03:00" level=info msg=" found better lib" lib=SD prio=6A4
2023-10-24T18:21:45.575Z daemon INFO time="2023-10-24T21:21:45+03:00" level=info msg=" discarded" lib=SD prio=640
time="2023-10-24T21:21:45+03:00" level=info msg=" found better lib" lib=SD prio=6A7
time="2023-10-24T21:21:45+03:00" level=info msg=" found better lib" lib=SD prio=6B0
2023-10-24T18:21:45.819Z daemon INFO time="2023-10-24T21:21:45+03:00" level=info msg="Resolving include SdFat.h for arch avr"
time="2023-10-24T21:21:45+03:00" level=info msg=" found better lib" lib=SdFat prio=6A6
2023-10-24T18:22:01.230Z daemon INFO time="2023-10-24T21:22:01+03:00" level=info msg="Required tool" tool="teensy:teensy-compile@11.3.1"
time="2023-10-24T21:22:01+03:00" level=info msg="Required tool" tool="teensy:teensy-tools@1.58.0"
2023-10-24T18:22:01.231Z daemon INFO time="2023-10-24T21:22:01+03:00" level=info msg="Required tool" tool="teensy:teensy-compile@11.3.1"
2023-10-24T18:22:01.237Z daemon INFO time="2023-10-24T21:22:01+03:00" level=info msg="Required tool" tool="teensy:teensy-compile@11.3.1"
[3040:1024/212331.493:ERROR:gpu_init.cc(523)] Passthrough is not supported, GL is disabled, ANGLE is
I couldn't figure out the cause of the problem. Does anyone have any ideas about this?
