go to line in text file
Hey, I have the Ethernet shield and want to got to a specific line in a text file...
What is the function for this? I think seek() only goes to a position not regarding the line....
M.
Below is some code from a while back that would extract data from a file by knowing where the desired data would be. In the last couple of days somebody posted code for getting temperature data and such from a RSS feed using TextFinder.h in the code.
//zoomkat 12-22-10
//simple ethernet client test code
//for use with IDE 0021 and W5100 ethernet shield
//modify the arduino lan ip address as needed
//open serial monitor to see what the arduino receives
//push the shield reset button to run client again
#include <SPI.h>
#include <Ethernet.h>
String readString, readString1;
int x=0;
char lf=10;
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
byte ip[] = { 192, 168, 1, 102 };
byte server[] = { 140, 90, 238, 27 }; // NOAA
Client client(server, 80);
  Ethernet.begin(mac, ip);
  Serial.println("starting simple arduino client test");
  Serial.println("connecting...");
  if (client.connect()) {
    Serial.println("connected");
    client.println("GET /data/5day2/44013_5day.txt HTTP/1.0");
    client.println();
    Serial.println("connection failed");
  if (client.available()) {
    char c = client.read();
    //Serial.print(c);  // uncomment to see raw feed
    if (c==lf) x=(x+1);
    if (x==14) readString += c;
    //readString += c;
  if (!client.connected()) {
     client.stop();
    Serial.println("Current data row:" );
    Serial.print(readString);
    readString1 = (readString.substring(41,43));
    Serial.print("DPD sec: ");
    Serial.println(readString1);
    Serial.println("done");
    for(;;);
