There is no "better", you need to meet a set of requirements, the set of requirements depends on
many things. Once you have the requirements you can figure out the possible power sources.
For batteries it is voltage, max current, capacity, temperature range, robustness, size, weight,
loss of capacity with charge-discharge cycles, internal self-discharge rate and similar things
that you may have to think about - some requirements are usually more required than others
too (hard requirements v. would be good to have)
MarkT:
Alright, guess it depends more on which project I am doing and what my needs are for said project. Thanks, I'll be sure to look around more about this.
