Gobetwino Freezing
Hi!
I am trying to use Gobetwino to collect the time from my computer and attach it to data from my Arduino. I am trying to synchronize it with other data timestamped from my computer, so I do not wish to use an RTC.
However, whenever I try to print my data to Gobetwino and save it to a .txt, it freezes after 3 samples. I thought I might be opening and closing my file too quickly, but I have put in delays and it does not change anything.
Here is my sample code, taken from the Gobetwino documentation.
int value = 877;
Serial.print("#S|LOGTEST|[");
Serial.print(itoa((value), buffer, 10));
Serial.println("]#");
My issue is similar to this unresolved thread: GoBetwine Freeze/Crash with Leonardo - Interfacing w/ Software on the Computer - Arduino Forum
Has anyone else had this problem before?
where is buffer declared?
I declared the buffer before setup. The code should look like this:
int value = 877;
char buffer[5];
I have no no experience with GoBetwino.
Did you try slowing down the writes? E.g. adding a delay of a second at the end of loop().
Note:
the other thread that you referred to was about a Leonardo. Which Arduino are you using?
In fact, I am able to replicate this error with the minimal example:
Serial.println("#S|T|[]#");
Furthermore, I have replicated it with multiple computers, added delays, and suppressed the status messages to test the problem. Gobetwino will unfreeze when I unplug my Arduino, but obviously, it will stop gathering the necessary data.
I feel like this should be spectacularly easy, but I am really at a loss.
Note: I am using an Arduino Micro.
