Gobetwino - passing a value to an exe file
After 3 hours of frustration ( lack of understanding and knowledge on my part ) I need help please.
In gobetwino, I have created a command called VBGO and the path to the app is : C:\Program Files\arduino\VBcontrol\ArdLog.exe and put $1 as the command line argument.
I want to pass the string, received from the Arduino, to the exe file as a command line option. The vb app ( the exe ) is set to read the command line data on startup and do what it needs to do with the data.
In the Arduino sketch ( experimenting with a temperature sensor ), I am using :
float tempC1 = readTemperature(outsideThermometer); float tempC2 = readTemperature(insideThermometer);
Serial.print("#S|VBGO|["); Serial.print("Temp Out : "); Serial.print(tempC1); Serial.println("]#"); Serial.print("#S|VBGO|["); Serial.print("Temp In : "); Serial.print(tempC2); Serial.println("]#");
but in the gobetwino is says :
Commandstring received : #S|VBGO|[Temp Out : 28.50]# The parameters in the command #S|VBGO|[Temp Out : 28.50]# are not correct for the command type.
PLEASE help. Severely frustrated.
Sorry, but you can't.
You can only pass cmd. line parametres defined in the command in GoBetwino.
I have a new version under way that will do what you want.
Thanks for the reply MikMO So I would have to use the 'write to a log file' option ( to get the text from the Arduino to the PC ) and then start the executable ( with no command line options ) and have the exe examine the log file to get the text data ?
