i am trying to program a simple code to go from my arduino to excel to produce a graph.
at the moment i am just trying to send number using this arduino code
int value1 = 1;
int value2 = 1;
int value3 = 1;
Serial.println("#S|SPXL|[]#"); // start EXCEL
{ sendValues();
value1 ++;
value2 ++;
value3 ++;
void sendValues()
//Send the values as though it was typed into Excell, using the SENDK command
// This is the total line that is send: #S,SENDK,[pId; potValue1 {TAB} potValue2 {DOWN} {LEFT} ]#
Serial.print("#S|SENDK|[");
Serial.print(value1);
Serial.print(" {TAB} ");
Serial.print(value2);
Serial.print(value3);
Serial.print(" {DOWN} ");
Serial.print(" {LEFT} ");
Serial.println("]#");
// wait up to 1000 ms for answer from Gobetwino, answer will be in serInString, answer is 0 if all is OK
//Deal with answer here - omitted in this example
delay(2000);
when i open gobetwino, the correct excel file is opend but no numbers are entered, the gobetwino window displays this:
16/04/2013 11:17:23 Serial port : COM3 opened at 9600 baud
16/04/2013 11:17:24 Commandstring recieved : #S|SPXL|[]#
16/04/2013 11:17:24 Command parsed OK
16/04/2013 11:17:24 Executing command : SPXL
16/04/2013 11:17:33 Process : C:\Users\Dani\Documents\Arduino\gobetwino\samples\trial.xls started. Proces ID = 0
16/04/2013 11:17:33 Commandstring recieved : #S|SENDK|[1 {TAB} 1 {TAB} 1 {DOWN} {LEFT} ]#
16/04/2013 11:17:33 The parameters in the command : #S|SENDK|[1 {TAB} 1 {TAB} 1 {DOWN} {LEFT} ]# are not correct for the command type
16/04/2013 11:17:33 Commandstring recieved : #S|SENDK|[2 {TAB} 2 {TAB} 2 {DOWN} {LEFT} ]#
16/04/2013 11:17:33 The parameters in the command : #S|SENDK|[2 {TAB} 2 {TAB} 2 {DOWN} {LEFT} ]# are not correct for the command type
16/04/2013 11:17:33 Commandstring recieved : #S|SENDK|[3 {TAB} 3 {TAB} 3 {DOWN} {LEFT} ]#
16/04/2013 11:17:33 The parameters in the command : #S|SENDK|[3 {TAB} 3 {TAB} 3 {DOWN} {LEFT} ]# are not correct for the command type
etc.
can anyone help as to why this does not display on the excel speadsheet please?
Sending data to an application via key strokes is a horrible way to do it, and I think with something as complex as Excel that's a recipe for disaster.
If you want to generate the 'spreadsheet' and then display it (not updating subsequently) then I'd just append all your data to a CSV file and then open the CSV file in Excel.
If you want the spreadsheet to display new data as it is received then there is a plug-in for Excel which enables it to receive data from a serial port and append to the current spreadsheet. This can be used to generate live charts, tables etc.
It was the sample code that I changed as I didn't need to send via email as it was suggesting, I purely just need to do a graph of how many times a person has entered a room, was thinking that I could do this using excel, so it arduino would update a value next to someone's name everything they enter. Just a very simple program is what I need.
What do you mean process id? I thought I was using sendk?
thank you once again for your quick response.
i see where you are now indicating (PID) and will implement it tomorrow and let you know how i get on.
richard
in your example you are using char then converting to int, the results i want to send are in integers to begin with,
what would my process ID be for this as yours is:
readSerialString(serInString, 5000); // wait 5 seconds (max) for answer from Gobetwino (=porcess ID)
pId= atoi(serInString); // convert result to integer
i dont understand what this means:
Serial.println("#S|SENDK|[PID&keystrokes to send]#"); Where PID is the process ID of the
program that the keystrokes is send to,
