Gobetwino SMAIL
Hi, i’ve been trying to send mail using gobetwino, attaching a .xls.
i’m getting -2 respond, which means “If the attachment file does not exist.” on the manual. but the attachment does exists, and linked in the gobetwino command.
i’ve also done port forwarding on my router, incase it was causing the mail not to go.
Please help.
Thanks :frowning:
int serInLen = 25;
char serInString[25];
int pId =0;
int result;
  Serial.println("#S|LOGRFID|[]#");        // start EXCEL
  readSerialString(serInString, 5000);  // wait  5  seconds (max) for answer from Gobetwino (=porcess ID)
  pId= atoi(serInString);               // convert result to integer
  sendPotValues();                       // send some data to Excell
   //analogValue= random(0,1023);
   //logData(analogValue);
   //delay(5000);
void sendPotValues()
   char buffer[5];
   int potValue1;
   int potValue2;
   for (int i=1; i<=5; i++){
     //Read the two pot values - could be any sensor value or whatever
     potValue1=analogRead(1);
     potValue2=analogRead(2);
    //Send the values as though it was typed into Excell, using the SENDK command
    // This is the total line that is send: #S,SENDK,[pId; potValue1 {TAB} potValue2 {DOWN} {LEFT} ]#
     Serial.print("#S|SENDK|[");
     Serial.print(itoa((pId), buffer, 10));
     Serial.print("&");
     Serial.print(itoa((potValue1), buffer, 10));
     Serial.print(" {TAB} ");
     Serial.print(itoa((potValue2), buffer, 10));
     Serial.print(" {DOWN} ");
     Serial.print(" {LEFT} ");
     Serial.println("]#");
     // wait up to 1000 ms for answer from Gobetwino, answer will be in serInString, answer is 0 if all is OK
     readSerialString(serInString, 1000);
     //Deal with answer here - omitted in this example
     delay(2000);
  // Now we have sent the 2 pot values 15 times, so save and close the XL sheet.
 Serial.print("& ");
 Serial.print("^s%{F4}");  //=  ctrl-S , alt-F4  = save and exit  Excell
 // Wait 2 seconds for the save to finish
 delay(2000);
 // Next e-mail the XL sheet to someone
 Serial.println("#S|HOT|[]#");
//read a string from the serial and store it in an array
//you must supply the array variable - will return if timeOut ms passes before the sting is read so you should
//check the contents of the char array before making any assumptions.
void readSerialString (char *strArray,long timeOut)
   long startTime=millis();
   int i;
   while (!Serial.available()) {
      if (millis()-startTime >= timeOut) {
         return;
   while (Serial.available() && i < serInLen) {
      strArray[i] = Serial.read();
      i++;
i just modified the sample a lil bit.
Thanks
Ignoring the Arduino for now, can you send email using the same process manually?
PaulS: Ignoring the Arduino for now, can you send email using the same process manually?
Could you please explain Me what you mean by same process manually? I know only via the arduino (with the help of the manual ).
Thank you very much.
