I want to look at the minimum overhead of using an ISR to adjust PWM duty cycle to control some external hardware. The basic task is just to output a byte value calculated elsewhere in the program.
I'm hoping to get this fast enough so that it won't disrupt SPI comm to SD using SDlib
volatile byte pwm=0;
ISR (TIMER2_OVF_vect,ISR_NAKED) {
OCR2B=pwm;
reti();
compiles to
00000248 <__vector_9>:
248: 80 91 7c 07 lds r24, 0x077C
24c: 80 93 b4 00 sts 0x00B4, r24
250: 18 95 reti
So I need to save/restore r24 and SREG
The normal ISR compiles to this:
248: 1f 92 push r1
24a: 0f 92 push r0
24c: 0f b6 in r0, 0x3f ; 63
24e: 0f 92 push r0
250: 11 24 eor r1, r1
252: 8f 93 push r24
254: 80 91 7c 07 lds r24, 0x077C
258: 80 93 b4 00 sts 0x00B4, r24
25c: 8f 91 pop r24
25e: 0f 90 pop r0
260: 0f be out 0x3f, r0 ; 63
262: 0f 90 pop r0
264: 1f 90 pop r1
266: 18 95 reti
already quite efficient However, I don't think r0 is relevant to lds and sts so saving and restoring is wasteful. Equally, I don't need to push and pop the SREG value, it will still be in r0.
With the help of Nick's article here:
I calculate that means I could save two push/pop pairs and the eor = 9 cycles out of 23 (not counting entry/exit overhead of 7. A worthwhile saving.
I think that leaves me with a hit of 21 cycles (1.3 us) to change PWM duty.
Anything I've missed ?
thanks.
