I am newbie, I purchased a LCD display for arduino and they send me the LCD and free a board named Golduino ??? What I can do with this board ? it has a at90usb162 and in their website there is a toturial to program the board with arduino ide... More info about this board ? code ? or I send it to trash ?
Are you not sure whether they did, or not? How are we supposed to know?
Who are "they"?
And that site is?
Is probably on the website you didn't provide the URL for.
code ?
Is probably on the website you didn't provide the URL for (in the tutorial).
Why would you do that? If you don't want it, offer it to someone here.
Sorry, but I think posting other shops urls are not allowed... I search info about this board and only see a youtube video, but no more...
If you have a problem/question/concern, then you need to post a URL. Otherwise, we can't help you.
By the way, sentences end in 1 period or 1 question mark, not however many you feel like using.
Don't forget exclamation marks!
An ellipsis is a valid end to a sentence, often used to portray a sense of melancholy. Perhaps the OP is sad about not being able to post links.
dxw00d:
A ellipsis is a valid end to a sentence, often used to portray a sense of melancholy. Perhaps the OP is sad about not being able to post links.
hahaha...
nice!
"The GOLDUINO Training Board is a low-cost demonstration board based on the AT90USB162 16kb microcontroller.
Training Board compatible Teensy / Blackcat USB / Arduino
Chip AT90USB162 programmable through USB
Male/Male MiniUSB-to-USB standard cable needed.
The GOLDEN AVR Training Board is a low-cost demonstration board based on the AT90USB162 16kb microcontroller. It allows the quick evaluation of AVR microcontrollers and the AT90USB family. Simply plugs into the USB port of a personal computer. Designers can either run demonstration programs or their own application. Programmable using the FLIP or Arduino Software with teensyduino addon compatible with Windows 98/Me/NT/2000/XP/Vista/7 "
Yes, not much info out there on it.
At the same time, is only a 32-pin device. If it is a device listed here
http://www.avr-developers.com/
you should be able to add the core files to your IDE setup, figure where the ISCP pins are,
and can download a bootloader into it so you can load up sketches.
AT90USB82/162 Complete datasheet:
