Good Automotive Solid State Relay?
I plan to use my Arduino to switch an ignition coil (I am making a Rev-Limiter). I need a solid state relay that can:
  1. Handle the current to drive an ignition coil (I did not measure but most coils draw a few amperes)
  2. Have an output range that includes 12v DC
  3. Accept a 5v DC input (from arduino)
  4. Switch fast
  5. Be cheap :slight_smile:
  6. Be normally closed (The arduino will switch the relay causing an OPEN circuit, disrupting power to the coil).
Since I am using a solid state relay would I need a transistor to drive it? If I do need a transistor will I need a protection diode?
Any suggestions?
Power MOSFETs.
Some of these have fantastically low on resistances of tenths or even hundredths of an Ohm, which allows them to switch big currents without even breaking a sweat.
If you need one end of the load (coil) to be connected to ground then you should use a P-Channel device. You can arrange for them to be normally-closed with a resistor from the gate to GND.
http://www.armory.com/~rstevew/Public/Motors/H-Bridges/Blanchard/figure-1.htm
Explains how to use them. You don't need an H-bridge, you just need the top left mosfet in the design above.
Draw yourself a schematic, make sure you understand it and try it all on breadboard switching a light bulb before you make it for real.
Mosfets have built in diodes that will provide some protection against back emf, but I would beef them up with a decent higher power diode.
