“good” needs to be specified more clearly. Do you need a good performance, a big size, a huge resolution or the number of colors?
Here are some generic statements:
Affordable RGB OLEDs seem to be very small (<= 128x128).
Graylevel OLEDs (for example SSD1322 and SSD1327) have poor performance and library support is limited.
SSD1306 is a standard controller for fast and reliable OLEDs with excellent lib spport. However resolution is limited to 128x64 pixel.
If you search for something beyond a SSD1306, try to google for
SSD1309 for OLEDs with a bigger size (still resolution is 128x64)
SH1107 for OLEDs with better resolution (up to 128x128)
What I mean by Good is one that is supported by good libraries so I can easily create graphics without having to hack the library or have to work with offsets.
128128 or 12864 is fine as long as I it has a clear image. It only has to display some graphics about RPM, %'s or battery indicator in a graphical way.
A bit like the standard 16x2 lcd but more graphic detail
If a monochrome display is good enough, then maybe try u8g2 (just install it via Arduino IDE Library Manager). Commands/graphics primitives are described here: u8g2reference · olikraus/u8g2 Wiki · GitHub
There are also many examples included and available in the Arduino IDE after installation.
Maybe do this: Get one of those cheap 128x64 SSD1306 Oleds. They usually can be connected directly to any Arduino Board. Then do some tests with some of the available libraries.
