That appears to be some impressive panic buying. Are you sure that you'll still be able to get hold of enough MCU chips to make use of all that lot?
I wanted to replenish my stocks of load switches TPS27081ADDCR. I must wait until 15.06.2022 so I'll make these from discrete components. But generally, I'm cutting back on my buying mainly because I am running out of storage space.
Quite honestly, I've been eyeing the news and wondering if I should try to stock up from Ali before the shipping slows or shipping prices go sky high... BTW I do support my local maker store too.
Have you got any protoboard/stripboard/veroboard to built your prototypes on?
You also need a set of standard through hole components, resistors and capacitors.
How can i make an adapter with to solder pads that connects the gate resistor when the solder pads is bridged with solder? I can't figure out how i can make the gate tied to the mosfet when the solder pads is not bridged.
