Google Voice to LCD Display (Scroll)
I want to make a project which works like this :
I shall use google’s voice recognition
It should convert into text
The app should send to arduino via bluetooth module
It should be displayed in a text in LCD with a scroll functions…
I am quite familiar with arduino , but not with the app…
Please help with the code and app
Thank You.
I have seen a lot of people using the MIT App Inventor for things like this, though I have no experience with it.
Sounds like your problem is not with the Arduino side so perhaps the Arduino forum is not the best place to ask. What will you be running the 'app' on. An iPhone? An Android phone? A PC? Each of those tends to be programmed differently and you should seek a forum specifically for the programming environment you plan to use.
johnwasser: Sounds like your problem is not with the Arduino side so perhaps the Arduino forum is not the best place to ask. What will you be running the 'app' on. An iPhone? An Android phone? A PC? Each of those tends to be programmed differently and you should seek a forum specifically for the programming environment you plan to use.
I want to use an android, Where should I ask then ? ( Do you know any programming fourms )
First result for a Google search: https://developer.android.com/support.html
They list half a dozen community resources for Android developers.
