Got a used Arduino MO PRO can not seem to get it working
Using the Web editor and have all installs correct. The board and port are selected/available correctly. What follows is the message I get:
Upload started
Programming with: Serial
Flashing with command:C:/Users/wescw/.arduino-create/arduino/openocd/0.10.0-arduino7/bin/openocd.exe -d2 -s C:/Users/wescw/.arduino-create/arduino/openocd/0.10.0-arduino7/share/openocd/scripts/ -f C:/Users/wescw/AppData/Local/Temp/extrafiles854567136/variants/arduino_mzero/openocd_scripts/arduino_zero.cfg -c telnet_port disabled; program {C:/Users/wescw/AppData/Local/Temp/arduino-create-agent955800133/Blink.bin} verify reset 0x4000; shutdown
Open On-Chip Debugger 0.10.0+dev-gf0767a31 (2018-06-11-13:36)
Licensed under GNU GPL v2
For bug reports, read
http://openocd.org/doc/doxygen/bugs.html
debug_level: 2
Info : auto-selecting first available session transport "swd". To override use 'transport select '.
none separate
adapter speed: 400 kHz
cortex_m reset_config sysresetreq
Info : CMSIS-DAP: SWD Supported
Info : CMSIS-DAP: JTAG Supported
Info : CMSIS-DAP: Interface Initialised (SWD)
Info : CMSIS-DAP: FW Version = 03.22.01B3
Info : SWCLK/TCK = 1 SWDIO/TMS = 1 TDI = 1 TDO = 1 nTRST = 0 nRESET = 1
Info : CMSIS-DAP: Interface ready
Info : clock speed 400 kHz
Info : SWD DPIDR 0x0bc11477
Info : at91samd21g18.cpu: hardware has 4 breakpoints, 2 watchpoints
Info : Listening on port 3333 for gdb connections
target halted due to debug-request, current mode: Thread
xPSR: 0x01000000 pc: 0x00003c94 msp: 0x20002d78
** Programming Started **
auto erase enabled
Info : SAMD MCU: SAMD21G18A (256KB Flash, 32KB RAM)
wrote 11776 bytes from file C:/Users/wescw/AppData/Local/Temp/arduino-create-agent955800133/Blink.bin in 1.091319s (10.538 KiB/s)
** Programming Finished **
** Verify Started **
verified 11608 bytes in 0.971623s (11.667 KiB/s)
** Verified OK **
** Resetting Target **
shutdown command invoked
The Zero has a similar issue reported. Read this post:
https://forum.arduino.cc/t/solved-arduino-zero-difficulties-getting-started/391408/4
Regrettably, I do not have any MO experience, but looks similar to the Zero issue.
Oh, and welcome to the forum!
Ray
Thank you,
I really have no idea what this unit has been through. I pulled it off an old prototype someone was done with at work. I have no idea where to find the people who worked with it originally. I just hope it's not broken in some way. I wouldn't be in any trouble I just wouldn't be able to learn from it anymore. There are two of them and both have the same issue. I have tried to use the non web version of arduino coding too.
Take an old battery transistor AM radio, tune it down in the 550-600KHz range with no station. Place the radio antenna near the Arduino, power up the Arduino, press reset. You should "hear" the Arduino processing. If dead, the AM radio will not receive the "hash" RF created by the digital circuits.
Thank you again, I'll have to find one somewhere. Might go by a pawn shop. Any ideas where I could get one from somewhere else?
The first option got it to work. Thank you again very much. I still plan to get that radio though, as I think that trick might help me later with some other old bits of circuitry and PCBs I have found with GPUs and microcontrollers on them.
It is a neat trick. Old transistor radios can often be found at yard sales, on eBay, or parents/family attics, basements, closets! You can even build one using a ferrite rod antenna and a few transistors. Even Amazon & WalMart have A.M. radio kits, although I think they are a weebit too expensive:
https://www.amazon.com/Elenco-Two-Radio-SOLDERING-REQUIRED/dp/B0041O4MFK/ref=asc_df_B0041O4MFK/
In the "old" days of the early '70's, You could get to know the "music" produced by your microcomputer as it would go through the various stages of boot-up to DOS; each I/O card had a ROM and unique sound as did the disk controller.
I just looked on eBay and found several "untested" units under $10, etc.
Unfortunately, there is an insane belief that old == rare == antique and that a $10 old transistor radio is worth hundreds of dollars; it is not. Beware of scams.
In addition to the A.M. radio kit, you could just build your own from a few scrap components:
https://www.ebay.com/itm/224553712441
https://www.homemade-circuits.com/simplest-am-radio-receiver-with-speaker/
The key feature is a ferrite inductor and variable capacitor so you can achieve a high Q resonant circuit and the ability to tune-out interference from home electronics and lighting: fluorescent lights being a really ugly noise maker.
