I was able to get an Atmega328p (DIP) working with the internal oscillator at 8mhz using a 5v supply, but now it won't run at 3.3v. I'm wondering if I neglected something with my fuse settings, since I've been able to boot 16mhz *duino boards at 3.3v in the past... Or, maybe some weird shenanigans because the firmware is made for the surface mount 'megas...?
My fuse settings and bootloader:
low fuses: 0xF2
high fuses: 0xDA
extended fuses: 0x05
bootloader: ATmegaBOOT_168_atmega328_pro_8MHz.hex
Thanks for the help
EDIT:
I just figured I'd copy the old revision '168-based Lilypad's fuse bits and now it runs fine. (Though if you notice I'm doing something bad with the fuses, tell me )
low fuses: 0xE2
high fuses: 0xDD
extended fuses: 0x00
Does anyone know where a nice fuse diagram for the 'megas (including the extended byte) is, and if the '168 and '328 fuse settings are the same? (it seems so from the datasheet I have...)
...the BOD level would be 2.7 volts. Did I misinterpret what the calculator is showing?
The original fuse settings are for "external clock" which is not the same as "external oscillator". Are you trying to run from the internal oscillator or from an external one?
This would leave BOD at 4.3V. He writes that this configuration is working (I assume at 3.3V), but this doesn't make sense. Rather it is reasonable to assume that he got the fuse settings mixed up somehow. The issue reported is consistent with an incorrect BOD setting (works at 5V, doesn't work at 3V3).
Figuring out fuse settings from the datasheet only is a hassle (using inverse logic) - using the Engbedded calculator makes it a lot easier.
Just a few questions regarding this:
I want to use the internal osci too, cause i want to fit a cell phone into a old-schools telephone... (and do need 3,3V to use)
I want to use the ArduinoISP-sketch. (i did succesfully burn some 328p...with 16MHz crystal)
If i setup the target 328. Do i need an oscillator (or crystal and Cs) on it?
Or can i leave out the two pins? Or need to tie high/low?
And:
I read, that the internal osci is quite unstable.
So: How unstable is it? Will i get serialconnection to work?
(i'm not sure how precise the timings have to be....)
