Gotta be a better way...
I'm sorry. You're gonna cringe.
There just has to be an easier way to go about this. I am very new to Arduino's and making circuits. I have most of my project working, but i want to know what is the best way to wire all these LEDs. I have so many wires here going into my MAX7219's and it's a huge rats nest. Should I not use wires at all and make solder traces all over the perfboard? If so, whats the best technique for that?
Just looking for suggestions. Yes i know this looks awful right now, but it works at the moment!
-Thanks
I was going to say use something like the 7219 but...... so I guess the real answer is to consider using a less archaic way to display information. An LCD panel could do the same job with four wires, so that gets pretty persuasive.
Bobsled:
How many 7219's are you using? A quick scan of the datasheet shows that two would suffice. I'd think seven segments x seven digits + seven segments x three digits would only be twenty-four wires. Looks like you've got a lot more.
You can try to etch your own PCB, you can use a heat transfer method with a laser printer and an iron :slight_smile:
Nick_Pyner:
This project that I'm working on is for someone else. They want these LED's specifically because we are making a custom hockey scoreboard for a board game. It's supposed to look lifelike when its done so we would like to stick with these LED's.
dougp:
I am using 2x 7219's. That should be all I need for this whole project. I haven't connected the last half of the LED's yet because its very tedious. And each of the single digit seven segments have 13 pins. 8 of them are for the segments (8 because of the DP), and the rest are the common cathodes (but you only need to use one of those). Then the 2 digit 7 segments on top have 18 pins each. So that's a current total of ~114 pins from the LED's that absolutely need connections.
cheche_romo:
I thought about doing something like this. I'll look into that more. I have all the tools necessary to do this.
Bobsled:
That doesn't sound right. Do you have a p/n or datasheet for the displays?
The other ideas are more elegant than mine, but, what about mounting the chips on the same board as the LED's? I have done that in the past, that makes the wires all short. I also put the wires in bundles with tie wraps so there is not the wild look, been doing the bundles thing for years
Last project was I think 27 LED's times two wires in a marine chart, put the wires in bundles and it did not look all that bad, should be a link I think to my web site in my name - look for the ATON display if you want - back maybe 10 posts or so
good luck with your project
When I use perfboard I use lengths of solid copper wire on the front side of the board to make connections between the copper tracks. That makes for neat and simple on-board connections. But of course it does nothing for inter-board connections
...R
Can you please post a copy of just how you connected the three digit display to the MAX7219 circuit, in CAD or a picture of a hand drawn circuit in jpg, png?
You should be able to connect all the a segments together at the display board, same with b ,c ,d, e, f, g and dp.
So for a 3 digit display you should have 8 wires (segment) + 3 wires (commons anode or cathode) = 11 wires
Thanks.. Tom.. :slight_smile:
Rather than bring every wire back to the 7219's - why not wire the busses locally...
All the a-segment together, the b-segment etc all the way through to all the dp’s.
Then you'd be looking at 2x 7219 = 2x 16 wires from the display controller to the LED panel. 8x segments and 8x commons.
As noted above in #2 (and allowing for 16x 8-segment displays incl dp).
(EDIT - Tom George beat me to it!)
Here is an example for a four digit display.
Tom... :slight_smile:
Connector blocks and ribbon cable?
Bobsled:
Looking at the picture again, and noting that there are actually only 10 LED characters, I just can't see how you can possibly have all that wire with two 7219s. OK, so the LED display I have has only 4 characters plus decimal points with one 7219, but I'm sure it only has twelve wires. With the mess like you have, and you say not all the LEDs are connected?, I can only assume that something else is going on that you're not telling us about.
Yes, mount the chip(s) on the perfboard. Here's one I did years ago.
Note: that's a saa1064 chip, not a max7219, but you get the idea.
lastchancename:
This would probably work best for me. I didn't even think about this solution haha. Thanks.
For everyone that asked, here are the links to the datasheets of the LEDs:
2 digit 7 segment
single digit 7 segment
Too late now, I suspect, but an alternative to the two max chips would be a single ht16k33 module. These can drive up to 16 digits. They use the i2c bus, so with the module soldered only the display PCB, only 4 wires would go back to the Uno.
