Gpio connect
I'm trying to connect an external gpio output to arduino.
The external gpio outputs the on/off status of a lamp.
Measuring the external gpio (gpio pin - > ground) it gives 0.26V when off and 26mV when on.
How do I safely connect this output to Arduino. Om afraid a pull-down resistor might overload the external Gpio port.
Is there a solution to make a passive switch so both units are isolated?
No answer because you have not given information - Web links to specifications, description of the device, photographs etc. - regarding what this "external gpio" actually is. :roll_eyes:
Called the "XY problem",
