Hello,
I have successfully interfaced GPIO Expander MCP23S18 (using SPI) with ESP32-S2 however I want to send values to the PLCC44 RGB LED's so as to obtain one color at a time and I am not sure of how to access and define the GPIO pins of the Expander. Can someone please help me with this. My code is as below: The GPIO pins on the Expander for R, G and B are 1, 4 and 3 respectively.
#define GPIO_MOSI 35
#define GPIO_MISO 37
#define GPIO_SCLK 36
#define GPIO_CS 33
#define GPIO_RED 1
#define GPIO_GREEN 4
#define GPIO_BLUE 3
static uint8_t state_low = 0;
static uint8_t state_high = 1;
#define WRITEADDR 0x40
#define IO_DIR_REG 0x00
#define GPIO_REG 0x09
#define SENDER_HOST SPI3_HOST
static const char *TAG = "GPIOEXP833";
esp_err_t ret;
spi_device_handle_t handle;
spi_transaction_t t;
uint8_t databuf[4];
uint8_t RGB_Color(int red_light, int green_light, int blue_light)
gpio_set_level(GPIO_RED, red_light);
gpio_set_level(GPIO_GREEN, green_light);
gpio_set_level(GPIO_BLUE, blue_light);
return 0;
int initgpio(task_t *_this)
if(_this->state > TASKSTATE_UNINITIALIZED) {
return -1;
gpio_config_t io_conf;
io_conf.intr_type = GPIO_PIN_INTR_DISABLE;
io_conf.mode = GPIO_MODE_OUTPUT;
io_conf.pin_bit_mask = (1ULL<<GPIO_CS);
io_conf.pull_down_en = 0;
io_conf.pull_up_en = 0;
gpio_config(&io_conf);
gpio_reset_pin(GPIO_CS);
gpio_set_direction(GPIO_CS, GPIO_MODE_OUTPUT);
gpio_reset_pin(GPIO_RED);
gpio_reset_pin(GPIO_GREEN);
gpio_reset_pin(GPIO_BLUE);
gpio_set_direction(GPIO_RED, GPIO_MODE_OUTPUT);
gpio_set_direction(GPIO_GREEN, GPIO_MODE_OUTPUT);
gpio_set_direction(GPIO_BLUE, GPIO_MODE_OUTPUT);
//Configuration for the SPI bus
spi_bus_config_t buscfg={
.mosi_io_num=GPIO_MOSI,
.miso_io_num=GPIO_MISO,
.sclk_io_num=GPIO_SCLK,
.quadwp_io_num=-1,
.quadhd_io_num=-1
//Configuration for the SPI device on the other side of the bus
spi_device_interface_config_t devcfg={
.command_bits=8,
.address_bits=8,
.dummy_bits=0,
.clock_speed_hz=1000000,
.duty_cycle_pos=128, //50% duty cycle
.mode=0,
.spics_io_num=GPIO_CS, //(1ULL<<GPIO_CS),
.cs_ena_pretrans=0,
.cs_ena_posttrans=3, //Keep the CS low 3 cycles after transaction, to stop slave from missing the last bit when CS has less propagation delay than CLK
.queue_size=1,
.flags=0,
.pre_cb=NULL,
.post_cb=NULL
//Initialize the SPI bus and add the device we want to send stuff to.
ret=spi_bus_initialize(SENDER_HOST, &buscfg, SPI_DMA_CH_AUTO);
assert(ret==ESP_OK);
ret=spi_bus_add_device(SENDER_HOST, &devcfg, &handle);
t.flags = 0x0000;
databuf[0]=0;
t.tx_buffer=(void*)databuf;
t.length=8;
t.cmd=WRITEADDR;
t.addr=IO_DIR_REG;
ret=spi_device_transmit(handle, &t);
_this->state = TASKSTATE_RUNNING;
return -1;
void execgpio(task_t *_this) {
gpio_set_level(GPIO_CS, state_low);
t.cmd=WRITEADDR;
t.addr=GPIO_REG;
databuf[0]= RGB_Color(0,255,0);
t.tx_buffer=databuf;
//ESP_LOGI(TAG, "return value %s", t);
gpio_set_level(GPIO_CS, state_high);
