I'm using an Arduino Due and noticed all the GPIOS are on HIGH during the bootloading of a sketch. I need the GPIOs to be on LOW. Is there a way to do it without adding resistors or any other components?
Are the pins driven logic high or in input pullup mode ?
And tell us what happens, during bootloading, for a pin that is normally high and you fit say a 10k pulldown resistor ?
And what state are the pins in when reset is held low ?
No, they float. They may appear to be high, because that's what you don't want, and Murphy's law.
No, you do need those resistors.
The bootloader would need to be altered either to turn off the input pullups, which default on at reset, or to set all the logic pins to output and low.
Pullup resistors are circa 100k.
So probably the easiest solution is to use 10k pull downs maybe.
