GPRS shield
I have the following GPRS shield.
I am trying to use it on an arduino mega with the GPRS Tx and Rx pins connected to Serial1.
But it appears that the only way I can do this is to go into the library source and change these defines:
#define _GSM_TXPIN_ 2
#define _GSM_RXPIN_ 3
It is a bit of a nuisance!
It would be nicer if there was a similar library with the same functionality and nice collection of example sketches which you could just pass in the Tx and Rx pins you want to use through a constructor or the begin(...) function.
Does such a library exist for these GPRS shields?
This would be a good opportunity for you to create and contribute one.
PaulS:
The damn GMSHIELD library won't even compile!
I don't get it - why is class HWSerial even needed?
Why can't HWSerial GSM::_cell; just be Stream *GSM::_cell;
And simply pass in a HardwareSerial or a SoftwareSerial object into the class constructor or the begin(...) function?
Oh, it looks like it has some additional functions:
int getString( char *pre_string, char *post_string, char *buffer, int length);
 boolean find(char *target);
 boolean  findUntil(char *target, char *terminate);
Still it seems to me it would be a lot more user friendly to just pass in a Stream object to the GSM class constructor and create a HWSerial objects around it internally.
Thus making this library work like most other libraries for serial devices seem to all work.
Because someone hacked together something that worked, and then said "F**k it. Good enough". When clearly it isn't. Try using that shield on a Mega, if you want to experience real frustration.
PaulS:
Which is was he does :wink:
Danois90:
Where did I miss that? The Leonardo and Due and Micro and several other Arduinos have a Serial1.
PaulS:
Second line in first post says: "I am trying to use it on an arduino mega" :slight_smile:
Danois90:
OK. I've got reading comprehension issues today. Missed that, despite looking after your last reply.
