GPS and CoG update
Hello...
I understand that COG = the position in which the GPS module is, in degrees, facing North, is this correct?
If yes ...
I tried the TinyGPSPlus, FullExample library and noticed in the console that the CoG column is very difficult to update.
I thought it was a problem with the bookstore and tried the U Center GPS, the result is the same.
Question... can something be done to update the COG like the rest of the data...?
Sorry for the google translation.
Thank you.
"COG" = Course Over Ground:
https://raymarine.custhelp.com/app/answers/detail/a_id/3337/~/heading-versus-cog
COG is Course over Ground which is the direction the GPS is moving in, calculated when there is movement between two fixes.
Thank you for the answers..
I suspected that he had to ... move.
Yes, I knew what COG was, but I only tried stationary,
I haven't tried it in motion yet, I will try it soon and let you know the result.
I also tried in motion, it updates .. a little faster, but not enough to use the course to London and COG calculations, controlling a servo, driving a car to a selected point., Maybe there is another driving option ..!! I did not find an example with GPS only. In combination GPS + Compass works excellently, but I want to try the simple version only GPS...
Thank you in advance...
What is your application?
How accurate and fast do you want your GPS information?
Thanks.. Tom.. :smiley: :+1: :coffee: :australia:
Thanks Tom.
I think the update speed would be enough 2-3 times per second.
I tried the option ... course to London - course to London... memorized,
but the radius in which it returns is large. Somehow you can get a maximum of 1m, I've seen some videos...but with boats.
In the version with compass ...compass - cours to london, the range is maximum 0.5m...
Eh? surely a course would be a bearing (degrees) - not a distance?
What accuracy of position fix are you getting?
AIUI, course is derived from position - so you can't get an accurate course if you're not getting an accurate position fix ...
Of course it is in degrees, but maybe the translation was a little messed up.
by radius I meant...
the car has its back to me and I want it to turn ... to me,
maybe now I understood myself better...regarding...the return radius
In the variant tried above, we obtained approximately 6m radius return, which we are not satisfied with.
A GPS will not tell you which way the car is pointing unless you move it enough of a distance forward\backwards that gets you a good COG.
To know which way the car is pointing you really need a compass.
Hello.
I know that movement is necessary, but it is also possible without a compass - Return home. I read the last comment about an autopilot and a friend has one..without a compass..I'm putting the link, so it's possible. I said that I tried, but it takes a long distance to return. The one bought by my friend turns a little wider than if it had a compass, but very satisfying.
If the COG is updated 2-3 times per second, it can replace the compass...
I hope the translation is understandable.
Autopilot...Автопилот АкваРобот научился разговаривать! - YouTube
