Hi guys, i'm new to the forum and beginner with arduino as well. My question is why arduino is writing only the first two digits from latitude, the first two before the dot. For example latitude 48.356789. Is working on Serial.print(flat, 10) but with eeprom.write(addr, flat) won't work, it's writing only 48 to eeprom. I'm trying to save the location to eeprom and then send it as sms with FONA from Adafruit. For now this is the only problem i'm struggling with. If its possible can i combine "flat" and "flong" in one address on eeprom?
Thanks in advance and sorry for my bad english.
#include <SoftwareSerial.h>
#include <TinyGPS.h>
#include <EEPROM.h>
TinyGPS gps;
SoftwareSerial ss(3, 4);
int addr = 0;
ss.begin(4800);
Serial.print("Simple TinyGPS library v. "); Serial.println(TinyGPS::library_version());
Serial.println("by Mikal Hart");
bool newData = false;
unsigned long chars;
unsigned short sentences, failed;
// For one second we parse GPS data and report some key values
for (unsigned long start = millis(); millis() - start < 1000;)
while (ss.available())
char c = ss.read();
// Serial.write(c); // uncomment this line if you want to see the GPS data flowing
if (gps.encode(c)) // Did a new valid sentence come in?
newData = true;
if (newData)
float flat, flon;
unsigned long age;
gps.f_get_position(&flat, &flon, &age);
Serial.println(flat, 10);
Serial.println(flon, 10);
//lat = flat;
EEPROM.write(addr, flat);
addr = addr + 1;
if (addr == 512)
addr = 0;
delay(3000);
EEPROM.write only writes one byte to the address but it is not writing the first of the 4 bytes. The floating point number 48.356789 will be converted to an unsigned character, which will result in 48, and that will be written to the address.
If flat is a float, then you are only writing the first of 4 bytes to the EEPROM.
You need to use a union and store the flat value in the float portion and then write all 4 bytes on the byte array portion to the EEPROM.
512/4 = 128, so you'll only get about 2 minutes worth of data. Why are you storing data in EEPROM, anyway?
Thanks for your response. What i'm trying to do is a "SOS BOX" ( press a button, log gps coordinates to eeprom, small delay, read that address from eeprom and use the "fona.sendSMS" command to send the location, or maybe convert the lat and long in a google maps link and then send it). I can allready use a button to send a sms, but again at fona command i can only use "fona.sendSMS("number", "message"); if i'm trying " fona.sendSMS("number", latitude, 16); won't work. Maybe there is another way to do it, for example "message = latitude + longitude" or something but i have no ideea. Hope you guys understand what i mean. Thanks for your time.
