hey.... i am trying to connect GPS and RFID reader together to an arduino UNO but, when i do so the gps does not give readings but rfid works properly... i guess is there any problem with the SS port..?? but i dont have any idea what changes should i make into my code... can someone please help asap...
Please read and follow the instructions in "How to use this forum".
jremington:
Sir.. i am not getting you... i previously posted other posts also in the same way... can someone help me wid the solution?? so kindly do...
What part of
do you not understand?
Let me spell it out.
Those instructions How to use this forum will tell you about asking a question. Key to this is posting a schematic of what you have and the code you are trying to run. This along with links to the parts you have will enable us to see what you are actually doing. Only then can we begin to try and work out what you are doing wrong.
Grumpy_Mike:
am so srry.. finally i understood... following is my code... its basically a vehicle security device... but am using rfid and gps on the same arduino uno board thus, the rfid is working properly but gps does not work at all.. but if i connect only gps modem then it gives me accurate reading... i guess the SS pin is problem.. is there any coding way by which i can assign a separate pin or something gps...
#include <Adafruit_GPS.h>
#include <SoftwareSerial.h>
SoftwareSerial gsm(1,0);
SoftwareSerial mySerial(3, 2);
Adafruit_GPS GPS(&mySerial);
boolean usingInterrupt = false;
void useInterrupt(boolean); // Func prototype keeps Arduino 0023 happy
#define GPSECHO true
#define TRIGPIN 4
#define ECHOPIN 5
#define RST_PIN 9 // Configurable, see typical pin layout above
#define SS_PIN 10 // Configurable, see typical pin layout above
#define MASTERCARD 4294943745
MFRC522 mfrc522(SS_PIN, RST_PIN); // Create MFRC522 instance
mySensor.initSensitivity(2); // Good for "Tilt" measurements
SPI.begin(); // Init SPI bus
mfrc522.PCD_Init(); // Init MFRC522
mfrc522.PCD_DumpVersionToSerial(); // Show details of PCD - MFRC522 Card Reader details
Serial.println(F("PLease Scan Your MASTERCARD..."));
pinMode(ECHOPIN, INPUT);
pinMode(TRIGPIN, OUTPUT);
pinMode(ledPin, OUTPUT); // declare LED as output
pinMode(inputPin, INPUT); // declare sensor as input
pinMode(pinSpeaker, OUTPUT);
// pinMode(buttonPin, INPUT);
GPS.begin(9600);
GPS.sendCommand(PMTK_SET_NMEA_OUTPUT_RMCGGA);
GPS.sendCommand(PMTK_SET_NMEA_UPDATE_1HZ); // 1 Hz update rate
GPS.sendCommand(PGCMD_ANTENNA);
useInterrupt(false);
mySerial.println(PMTK_Q_RELEASE);
SIGNAL(TIMER0_COMPA_vect) {
char c = GPS.read();
#ifdef UDR0
if (GPSECHO)
if (c) UDR0 = c;
#endif
void useInterrupt(boolean v) {
if (v) {
OCR0A = 0xAF;
TIMSK0 |= _BV(OCIE0A);
usingInterrupt = true;
TIMSK0 &= ~_BV(OCIE0A);
uint32_t timer = millis();
//THE TOUGHEST AND CRUCIAL PART i.e THE ACTUALL PROGRAMMING
unsigned long getID(){
if ( ! mfrc522.PICC_ReadCardSerial()){
return -1;
unsigned long hex_num;
hex_num = mfrc522.uid.uidByte[0] << 24;
hex_num += mfrc522.uid.uidByte[1] << 16;
hex_num += mfrc522.uid.uidByte[2] << 8;
hex_num += mfrc522.uid.uidByte[3];
mfrc522.PICC_HaltA(); // Stop reading
return hex_num;
unsigned long uid;
if(mfrc522.PICC_IsNewCardPresent()) {
uid = getID();
if(uid != -1)
Serial.print("Card detected, UID: "); Serial.println(uid);
if((uid==MASTERCARD) && (mfrc522.PICC_IsNewCardPresent())){
Serial.println("Enjoy Your Drive.. :)");
digitalWrite(ledPin,HIGH);
//GPS CODING...!!!!!
if (! usingInterrupt) {
// read data from the GPS in the 'main loop'
// if you want to debug, this is a good time to do it!
if (GPSECHO)
if (c) Serial.print(c);
// if a sentence is received, we can check the checksum, parse it...
if (GPS.newNMEAreceived()) {
if (!GPS.parse(GPS.lastNMEA())) // this also sets the newNMEAreceived() flag to false
return; // we can fail to parse a sentence in which case we should just wait for another
// if millis() or timer wraps around, we'll just reset it
if (timer > millis()) timer = millis();
// approximately every 2 seconds or so, print out the current stats
if (millis() - timer > 2500) {
timer = millis(); // reset the timer
Serial.print("\nTime: ");
Serial.print(GPS.hour, DEC); Serial.print(':');
Serial.print(GPS.minute, DEC); Serial.print(':');
Serial.print(GPS.seconds, DEC); Serial.print('.');
Serial.println(GPS.milliseconds);
Serial.print("Date: ");
Serial.print(GPS.day, DEC); Serial.print('/');
Serial.print(GPS.month, DEC); Serial.print("/20");
Serial.println(GPS.year, DEC);
Serial.print("Fix: "); Serial.print((int)GPS.fix);
Serial.print(" quality: "); Serial.println((int)GPS.fixquality);
// if (GPS.fix) {
Serial.print("Location: ");
Serial.print(GPS.latitude, 4); Serial.print(GPS.lat);
Serial.print(", ");
Serial.print(GPS.longitude, 4); Serial.println(GPS.lon);
Serial.print("Location (in degrees, works with Google Maps): ");
Serial.print(GPS.latitudeDegrees, 4);
Serial.print(", ");
Serial.println(GPS.longitudeDegrees, 4);
Serial.print("Speed (knots): "); Serial.println(GPS.speed);
Serial.print("Angle: "); Serial.println(GPS.angle);
Serial.print("Altitude: "); Serial.println(GPS.altitude);
Serial.print("Satellites: "); Serial.println((int)GPS.satellites);
//delay(10000);
Serial.println("");
Serial.println("Sending to Database...");
Serial.println("");
Serial.println("");
Please edit your post and USE CODE TAGS, not quote tags, as instructed in "How to use this forum".
I can see that this is going to take a while.
When you get around to it (tomorrow or the next day, no one really cares), also post a wiring diagram.
jremington:
Please edit your post and USE CODE TAGS, not quote tags, as instructed in "How to use this forum".I can see that this is going to take a while.
hey... i hav edited my code... can u just have a look?? i am really very screwed with SS pin thtz SPI bus... plz can u provide some hlp asap... i hav to submit my project in few days..
its kind of urgent ![]()
Yes, this seems to be extremely urgent. It took you 4 days to edit the previous post.
Where is your wiring diagram?
jremington:
Yes, this seems to be extremely urgent. It took you 4 days to edit the previous post.Where is your wiring diagram?
No sir.. i edited it the same day.,, but i thought u might see it... but there weren't any replies so i posted again today...
m confused with how to upload my wiring diagram... ![]()
Draw the diagram on pencil and paper, then scan or take a photo and post it. The instructions are in "How to use this forum".
sir.. i have modified my code... thtz below..
#include <LiquidCrystal.h>
#include <SPI.h>
//#include <Wire.h> //Include the Wire library
#include <MMA_7455.h> //Include the MMA_7455 library
#include <MFRC522.h>
int SS_PIN = 14;
int RST_PIN = 9;
SoftwareSerial gsm(10,9);
SoftwareSerial mySerial(16,15 );
MMA_7455 tilt = MMA_7455(); //Make an instance of MMA_7455
LiquidCrystal lcd(0, 1, 5, 4, 3, 2);
char xVal, yVal, zVal;
int backLight = 6;
int TRIGPIN = 7;
int ECHOPIN = 8;
int pir = 17;
int pirState = LOW;
int val = 0;
int speaker = 13;
int red = 12;
int green = 11;
SPI.begin();
pinMode(backLight, OUTPUT);
digitalWrite(backLight, HIGH);
lcd.begin(16, 2);
lcd.clear();
lcd.print(F("Please Insert Ur"));
lcd.setCursor(2,1);
lcd.print(F("MASTERCARD"));
delay(10000);
digitalWrite(backLight, LOW);
delay(2000);
digitalWrite(backLight,LOW);
delay(100);
tilt.initSensitivity(2);
pinMode(red, OUTPUT);
pinMode(green,OUTPUT);
pinMode(pir, INPUT);
pinMode(speaker, OUTPUT);
GPS.begin(9600);
/*Code to get Card UID */
return -1;
return hex_num;
analogWrite(SS_PIN,100);
unsigned long uid;
uid = getID();
if(uid != -1)
Serial.print(F("Card detected, UID: ")); Serial.println(uid);
if(uid==MASTERCARD){
delay(10);
lcd.clear();
lcd.print(F("Enjoy Your Drive.. "));
lcd.setCursor(0,1);
lcd.print(F(":)"));
pinMode(backLight,HIGH);
delay(10000);
lcd.clear();
digitalWrite(green,HIGH);
digitalWrite(green,LOW);
xVal = tilt.readAxis('x'); //Read out the 'x' Axis
yVal = tilt.readAxis('y'); //Read out the 'y' Axis
zVal = tilt.readAxis('z'); //Read out the 'z' Axis
if (xVal < -20 || xVal > 20 || zVal < -45 )
Serial.println("");
tone(speaker, 500, 1000);
lcd.clear();
lcd.setCursor(2,0);
lcd.print(F("Accident"));
lcd.setCursor(2,1);
lcd.print(F("Detected"));
digitalWrite(red,HIGH);// turn LED On
digitalWrite(red,LOW);// turn LED On
if (GPSECHO)
if (GPS.fix) {
Serial.print(", ");
Serial.print(", ");
//delay(10000);
Serial.println("");
Serial.println("");
Serial.println("");
// Ultrasonic Sensor...!!!!
digitalWrite(TRIGPIN, LOW);
delayMicroseconds(1000);
digitalWrite(TRIGPIN, HIGH);
//Distance calculation
float distance = pulseIn(ECHOPIN, HIGH);
distance= distance/58;
if (distance>=2 && distance<=50){
lcd.clear();
lcd.setCursor(1,0);
lcd.print(distance);
lcd.println(F(" cm"));
lcd.setCursor(3,1);
lcd.print("DANGER");
tone(speaker, 500, 500);
Serial.println("");
else {
lcd.clear();
noTone(speaker);
// IF FAKE CARD INSERTED...!!!
else {
lcd.clear();
lcd.setCursor(0,0);
lcd.println(F("Access Denied..."));
lcd.clear();
lcd.setCursor(0,1);
lcd.println(F(":( ..."));
exit;
// PIR MOTIION SENSOR WHEN CARD IS ABSENT....!!!
val = digitalRead(pir); // read Sensor_Pin
if (val == HIGH) // check if the input is HIGH
digitalWrite(red,HIGH); // turn LED On
lcd.clear();
lcd.setCursor(0,0);
lcd.print(F("UNAUTHORISED"));
lcd.setCursor(2,1);
lcd.print("ACCESS...");
else {
noTone(speaker);
and i have come up with this wiring diagram... will tht be a good reference to u??
Sir kindly let me knw if its still isn't proper... i'll make the necessary changes...
sorry as its a little unclear...
Lots of ground connections missing in your diagram. You didn't mention the LCD, the GSM module or the ultrasonic sensor in your original post.
I don't see how this can ever work -- the most obvious problem is that according to the diagram and the code, the LCD is using the serial pins D0 and D1, but that conflicts with using those pins for the serial port, which is also defined in the code.
You need to separate out the individual pieces and get each one working before putting everything together.
jremington:
Lots of ground connections missing in your diagram. You didn't mention the LCD, the GSM module or the ultrasonic sensor in your original post.I don't see how this can ever work -- the most obvious problem is that according to the diagram and the code, the LCD is using the serial pins D0 and D1, but that conflicts with using those pins for the serial port, which is also defined in the code.
Yes... i added the components after posting the original post... as my project includes them...
And When i enable the lcd in actual practise.. i remove the serial commands...
and that abt gnd and vcc i have connected them all to the breadboard properly...
i thought this wiring diagram wud give the rough and basic idea of wat m trying to do...
Thanks fr the info u gav me...
also can u suggest something more tht i can do??
can spi or I2c help??
