GPS based theft detection system
I am looking for opinions only and perhaps confirmation that an idea I have may work, I am not looking for some one to design this for me or write code, I just need to know that it is feasible.
This system will eventually be installed in a trailer mounted A.C. Generator and will need to send positioning information if the trailer is stolen.
Currently the system uses cellphone/GPRS communication and the parent station polls the generator on a regular basis (every few minutes) to confirm its location. This system is powered by the Generator Start battery which in turn will be maintained by a small Solar array.
In order to reduce the daily current draw on the battery I would like to build a solution that listens for a query from the GPRS unit and also monitors the GPS module. If the GPS position changes by "X" then it sends a "help I am being stolen" type message and continues to transmit its location etc.
Is it better to use difference in GPS position as a trigger or maybe add something to detect the initial movement I.E. a accelerometer or similar to wake it up?
Ideally I would like to reduce the transmissions to one or two per day in normal circumstances.
Thanks in advance
If the generator is moved to a place with no cell phone coverage (or the GPRS module is removed), what is the plan?
An alternative is to occasionally wake up and send a location via a satellite. This works anywhere in the world and is not very expensive.
Products that I'm considering are SPOT Trace and RockBlock, which is much more flexible than SPOT.
I assume you know the usual trailer anti-theft ideas like a locking ball and chaining a wheel.
So the determined thief is your target, right?
The GPS-Movement trigger sounds good. BUT you need to find out how much the nominal location moves under typical conditions. I know my truck parked at home ends up with a track about 100 feet across after a couple of weeks.
And what if it's parked in a garage?
But accelerometer would need to be check often to capture "Hitch to the thief's old pickup" movement.
Hmmm....
Thanks guys,
I realise no system is fool proof, but we can reduce some of the issues. For instance sat phone or radio comms are options that are commonly used here in NZ.
It will be hard to overcome putting it in a garage but if we can track it to the building its a start.
As for the nominal movement, I had thought of that, which is why I looked at sensing movement to trigger the alert.
Often this equipment is picked up by a HIAB truck so the towball and wheel locks aren't much use.
I was hoping that the accelerometer could be read continuously and if the reading went out of tolerance started the location transmissions.
jremington:
I want to avoid having to regularly send data, I would prefer to only send when there was a potential issue.
Have you considered a simple tilt switch. I've got some, comprising a little ball of mercury which can roll about and contact a pair of wires. Using one or more of these would give you a signal that something was going on. (You'd have to experiment a little to get the action right, i.e., always alarms when it should, no false alarms.)
Suppose you build a little Arduino type circuit which reads position every minute, and sends out a text message. You power this through a relay the coil of which is activated by the tilt switch. You could use a latching relay, or just wrap the power supply back so that once the circuit becomes active, the relay remains energized.
And as to absence of phone service, I would expect that you wouldn't be setting this up on a carrier that had no local coverage.
So once activated, you get once/minute updates. Before activation, it uses no power at all.
Take a look at geofencing - that way you could specify the whole worksite as 'allowed' but going off site would trigger the tracking event.
There are other strategies you could look at - like detecting the proximity to a paired device in the site office, and take over from there.
An accelerometer like the ADXL345 can detect movement and wake up the main processor. I think you can run that on a coin cell battery for a month or two. I never really looked into it but I use about 30 of them for other jobs that aren't power constrained.
So long as your thief isn't smart enough to put a tinfoil hat on the GPS before lifting the trailer, this should be good. When moving and outside the geofence, send an update every 30sec.
