GPS Bee and Seeeduino Stalker
I'm trying to use a GPS Bee with a Seeeduino Stalker2.0, but I'm not able to obtain nmea string, either in the bee slot and using a seeedstudio xbeeShield. No problem when I link an xbee module in these 2 places.
No problem when I use a GPS Bee with a regular Arduino and a XbeeShield.
Here the code I use:
Program that read a char from serial port and turn on a led (pin 13)
 if the char was H. Put it low is the char is an L
 /* parallax code */
//int ledPin = 13;
#include <Wire.h>
char string[32];
char byteRead;
int ledPin = 13;                  // LED test pin
 int rxPin = 0;                    // RX PIN
 int txPin = 1;                    // TX TX
 int byteGPS=-1;
 char linea[300] = "";
 char comandoGPR[7] = "$GPRMC";
 int cont=0;
 int bien=0;
 int conta=0;
 int indices[13];
  // initialize serial communication:
  /* parallax code */
  for (int i=0;i<300;i++){       // Initialize a buffer for received data
     linea[i]=' ';
  // initialize the LED pins:
 // pinMode(ledPin, OUTPUT);
   digitalWrite(ledPin, HIGH);
   byteGPS=Serial.read();         // Read a byte of the serial port
   if (byteGPS == -1) {           // See if the port is empty yet
     delay(100);
     linea[conta]=byteGPS;        // If there is serial port data, it is put in the buffer
     conta++;
     Serial.print(byteGPS, BYTE);
  // read the port:
 int availableBytes = Serial.available();
for(int i=0; i<availableBytes; i++)
    string[i] = Serial.read();
Serial.print(string);
Thank you for any opinion!
Marco.
No suggestion?
