yes, the LED is blinking
#include <Keypad.h>
#include <TinyGPS++.h>
TinyGPSPlus gps;
#define GPS_BAUDRATE 115200
const byte ROWS = 4;
const byte COLS = 4;
char keys[ROWS][COLS] = {
{'1','2','3','A'},
{'4','5','6','B'},
{'7','8','9','C'},
{'*','0','#','D'}
byte rowPins[ROWS] = {19, 18, 5, 17};
byte colPins[COLS] = {16, 4, 0, 2};
Keypad keypad = Keypad(makeKeymap(keys), rowPins, colPins, ROWS, COLS);
const int buzzer = 27;
const int led = 26;
const int ledm = 25;
const int kunci = 13;
String code = "";
String kodeotp[] = {
"123A", "456B", "789C",
"215D", "378A", "491B",
"324C", "587D", "916A",
"431B", "692C", "874D",
"567A", "239B", "148C",
"689D", "745A", "312B",
"741C", "826D", "593A",
"856B", "194C", "327D",
"978A", "563B", "412C",
"124D", "895A", "637B",
"111A", "0A"}; // buat tes
bool OTP = false;
int errorCount = 0;
// Geo-Fence (in meters)
const float maxDistance = 30;
// Initial Lat Long
float initialLatitude = -7.320905905572536; //puslet
float initialLongitude = 112.76811401532106;
float latitude, longitude;
Serial.println("Initializing");
pinMode(buzzer, OUTPUT);
pinMode(led, OUTPUT);
pinMode(ledm, OUTPUT);
pinMode(kunci, OUTPUT);
Serial.println("NEO6M Serial Initialize");
Serial2.begin(GPS_BAUDRATE);
//gps.begin(115200); //neogps
char key = keypad.getKey();
if (key) {
Serial.println(key);
if (key == '#') {
for (String correctCode : kodeotp) {
if (code == correctCode) {
OTP = true;
if (OTP) {
digitalWrite(buzzer, HIGH);
delay(90);
digitalWrite(buzzer, LOW);
delay(90);
delay(90);
digitalWrite(led, HIGH);
digitalWrite(kunci, HIGH);
Serial.println("Silahkan Ambil Sepeda");
delay(3000);
digitalWrite(led, LOW);
digitalWrite(kunci, LOW);
errorCount = 0;
Serial.println("OTP Salah");
for (int i = 0; i < 3; i++) {
digitalWrite(ledm, HIGH);
delay(90);
digitalWrite(ledm, LOW);
delay(90);
errorCount++;
if (errorCount >= 3){
Serial.println("Sepeda Diblokir Hubungi Admin");
for (int i = 0; i < 20; i++) { //jangan lupa diganti 50x ya
delay(350);
delay(150);
errorCount = 0;
code = ""; // Reset code
OTP = false;
} else if (key == '*') {
code = "";
Serial.println("----------");
code += key;
getGps(latitude, longitude);
float distance = getDistance(latitude, longitude, initialLatitude, initialLongitude);
Serial.print("Latitude= "); Serial.println(latitude, 6);
Serial.print("Lngitude= "); Serial.println(longitude, 6);
Serial.print("initialLatitude= "); Serial.println(initialLatitude, 6);
Serial.print("initialLngitude= "); Serial.println(initialLongitude, 6);
Serial.print("current Distance= "); Serial.println(distance);
if(distance > maxDistance) {
else{
// Calculate distance between two points
float getDistance(float flat1, float flon1, float flat2, float flon2) {
// Variables
float dist_calc=0;
float dist_calc2=0;
float diflat=0;
float diflon=0;
// Calculations
diflat = radians(flat2-flat1);
flat1 = radians(flat1);
flat2 = radians(flat2);
diflon = radians((flon2)-(flon1));
dist_calc = (sin(diflat/2.0)*sin(diflat/2.0));
dist_calc2 = cos(flat1);
dist_calc2*=cos(flat2);
dist_calc2*=sin(diflon/2.0);
dist_calc +=dist_calc2;
dist_calc=(2*atan2(sqrt(dist_calc),sqrt(1.0-dist_calc)));
dist_calc*=6371000.0; //Converting to meters
return dist_calc;
void getGps(float& latitude, float& longitude)
// Can take up to 60 seconds
boolean newData = false;
for (unsigned long start = millis(); millis() - start < 2000;){
while (Serial2.available()){
if (gps.encode(Serial2.read())){
newData = true;
Serial.println("newData is true");
else {
Serial.println("newData is false");
if (newData) //If newData is true
latitude = gps.location.lat();
longitude = gps.location.lng();
newData = false;
else {
Serial.println("No GPS data is available");
latitude = 0;
longitude = 0;
