I'm using a GPS shield from Adafruit and I'm able to receive data, but am not able to log it to the SD card, it says "Card init. failed!" >:(. Any idea why this is happening?
M
M
Once you've made your first post, you can post links. You can also edit your first post to add links.
The first link you should post is the link to the particular shield you have.
There may be things you need to do with your card before you can use it in the shield - format it, for instance. The shield should have come with instructions, or they may be on the web site. If we knoew shich shield you had, we might be able to provide some answers, or ask better questions.
This is the shield that I have: Adafruit GPS logger shield kit [v1.1] : ID 98 : $19.50 : Adafruit Industries, Unique & fun DIY electronics and kits
I'm attaching photos of my shield. I checked the shield with the GPSlogger_v3 sketch with 4 different SD cards and none seem to get rid of the Card init. failed message.
C:\Users\Marvin Rusinek\Desktop\1.jpg
C:\Users\Marvin Rusinek\Desktop\2.jpg
Here are the images of my shield
hops ttp://mysite.pratt.edu/~mrusinek/1.jpg
last pic pins should be connected as follows: TX->0 RX-1> PWR->2 LED2 ->3 LED1 -> 4
I got the shield recognizing the card! However, it's still not logging the data to the card.
This is the output from the serial monitor:
writing to GPSLOG00.TXT
ready!
$PSRF100,01,4800,08,01,000E
$PSRF105,013E
$PSRF103,00,00,00,0124
$PSRF103,01,00,00,0127
$PSRF103,02,00,00,0126
$PSRF103,03,00,00,0127
$PSRF103,04,00,01,0121
$PSRF103,05,00,00,0121
$PSRF151,00*3E
~____________________________
Your code? You want to post it?
I'm using the code from Adafruit:
/* Code starts here - call it GPSLogger_v2.1 :) */
// this is a generic logger that does checksum testing so the data written should be always good
// Assumes a sirf III chipset logger attached to pin 0 and 1
#include "AF_SDLog.h"
#include "util.h"
#include <avr/pgmspace.h>
#include <avr/sleep.h>
// power saving modes
#define SLEEPDELAY 0
#define TURNOFFGPS 0
#define LOG_RMC_FIXONLY 1
AF_SDLog card;
File f;
#define led1Pin 4
#define led2Pin 3
#define powerPin 2
#define BUFFSIZE 75
char buffer[BUFFSIZE];
uint8_t bufferidx = 0;
uint8_t fix = 0; // current fix data
uint8_t i;
/* EXAMPLE
$PSRF103,<msg>,<mode>,<rate>,<cksumEnable>*CKSUM<CR><LF>
<msg> 00=GGA,01=GLL,02=GSA,03=GSV,04=RMC,05=VTG
<mode> 00=SetRate,01=Query
<rate> Output every <rate>seconds, off=00,max=255
<cksumEnable> 00=disable Checksum,01=Enable checksum for specified message
Note: checksum is required
Example 1: Query the GGA message with checksum enabled
$PSRF103,00,01,00,01*25
Example 2: Enable VTG message for a 1Hz constant output with checksum enabled
$PSRF103,05,00,01,01*20
Example 3: Disable VTG message
$PSRF103,05,00,00,01*21
#define SERIAL_SET "$PSRF100,01,4800,08,01,00*0E\r\n"
// GGA-Global Positioning System Fixed Data, message 103,00
#define LOG_GGA 0
#define GGA_ON "$PSRF103,00,00,01,01*25\r\n"
#define GGA_OFF "$PSRF103,00,00,00,01*24\r\n"
// GLL-Geographic Position-Latitude/Longitude, message 103,01
#define LOG_GLL 0
#define GLL_ON "$PSRF103,01,00,01,01*26\r\n"
#define GLL_OFF "$PSRF103,01,00,00,01*27\r\n"
// GSA-GNSS DOP and Active Satellites, message 103,02
#define LOG_GSA 0
#define GSA_ON "$PSRF103,02,00,01,01*27\r\n"
#define GSA_OFF "$PSRF103,02,00,00,01*26\r\n"
// GSV-GNSS Satellites in View, message 103,03
#define LOG_GSV 0
#define GSV_ON "$PSRF103,03,00,01,01*26\r\n"
#define GSV_OFF "$PSRF103,03,00,00,01*27\r\n"
// RMC-Recommended Minimum Specific GNSS Data, message 103,04
#define LOG_RMC 1
#define RMC_ON "$PSRF103,04,00,01,01*21\r\n"
#define RMC_OFF "$PSRF103,04,00,00,01*20\r\n"
// VTG-Course Over Ground and Ground Speed, message 103,05
#define LOG_VTG 0
#define VTG_ON "$PSRF103,05,00,01,01*20\r\n"
#define VTG_OFF "$PSRF103,05,00,00,01*21\r\n"
// Switch Development Data Messages On/Off, message 105
#define LOG_DDM 1
#define DDM_ON "$PSRF105,01*3E\r\n"
#define DDM_OFF "$PSRF105,00*3F\r\n"
#define USE_WAAS 0 // useful in US, but slower fix
#define WAAS_ON "$PSRF151,01*3F\r\n" // the command for turning on WAAS
#define WAAS_OFF "$PSRF151,00*3E\r\n" // the command for turning off WAAS
// read a Hex value and return the decimal equivalent
uint8_t parseHex(char c) {
if (c < '0')
return 0;
if (c <= '9')
return c - '0';
if (c < 'A')
return 0;
if (c <= 'F')
return (c - 'A')+10;
// blink out an error code
void error(uint8_t errno) {
while(1) {
for (i=0; i<errno; i++) {
digitalWrite(led1Pin, HIGH);
digitalWrite(led2Pin, HIGH);
delay(100);
digitalWrite(led1Pin, LOW);
digitalWrite(led2Pin, LOW);
delay(100);
for (; i<10; i++) {
delay(200);
WDTCSR |= (1 << WDCE) | (1 << WDE);
WDTCSR = 0;
Serial.begin(4800);
putstring_nl("\r\nGPSlogger");
pinMode(led1Pin, OUTPUT);
pinMode(led2Pin, OUTPUT);
pinMode(powerPin, OUTPUT);
digitalWrite(powerPin, LOW);
if (!card.init_card()) {
putstring_nl("Card init. failed!");
error(1);
if (!card.open_partition()) {
putstring_nl("No partition!");
error(2);
if (!card.open_filesys()) {
putstring_nl("Can't open filesys");
error(3);
if (!card.open_dir("/")) {
putstring_nl("Can't open /");
error(4);
strcpy(buffer, "GPSLOG00.TXT");
for (buffer[6] = '0'; buffer[6] <= '9'; buffer[6]++) {
for (buffer[7] = '0'; buffer[7] <= '9'; buffer[7]++) {
//putstring("\ntrying to open ");Serial.println(buffer);
f = card.open_file(buffer);
if (!f)
card.close_file(f);
if (!f)
if(!card.create_file(buffer)) {
putstring("couldnt create ");
error(5);
if (!f) {
putstring("error opening ");
card.close_file(f);
error(6);
putstring("writing to ");
putstring_nl("ready!");
putstring(SERIAL_SET);
delay(250);
if (LOG_DDM)
putstring(DDM_ON);
putstring(DDM_OFF);
delay(250);
if (LOG_GGA)
putstring(GGA_ON);
putstring(GGA_OFF);
delay(250);
if (LOG_GLL)
putstring(GLL_ON);
putstring(GLL_OFF);
delay(250);
if (LOG_GSA)
putstring(GSA_ON);
putstring(GSA_OFF);
delay(250);
if (LOG_GSV)
putstring(GSV_ON);
putstring(GSV_OFF);
delay(250);
if (LOG_RMC)
putstring(RMC_ON);
putstring(RMC_OFF);
delay(250);
if (LOG_VTG)
putstring(VTG_ON);
putstring(VTG_OFF);
delay(250);
if (USE_WAAS)
putstring(WAAS_ON);
putstring(WAAS_OFF);
//Serial.println(Serial.available(), DEC);
char c;
uint8_t sum;
// read one 'line'
if (Serial.available()) {
c = Serial.read();
//Serial.print(c, BYTE);
if (bufferidx == 0) {
while (c != '
c = Serial.read(); // wait till we get a $
buffer[bufferidx] = c;
if (c == '\n') {
//putstring_nl("EOL");
//Serial.print(buffer);
buffer[bufferidx+1] = 0; // terminate it
if (buffer[bufferidx-4] != '') {
// no checksum?
Serial.print('', BYTE);
bufferidx = 0;
return;
// get checksum
sum = parseHex(buffer[bufferidx-3]) * 16;
sum += parseHex(buffer[bufferidx-2]);
// check checksum
for (i=1; i < (bufferidx-4); i++) {
sum ^= buffer[i];
if (sum != 0) {
//putstring_nl("Cxsum mismatch");
Serial.print('~', BYTE);
bufferidx = 0;
return;
// got good data!
if (strstr(buffer, "GPRMC")) {
// find out if we got a fix
char *p = buffer;
p = strchr(p, ',')+1;
p = strchr(p, ',')+1; // skip to 3rd item
if (p[0] == 'V') {
fix = 0;
fix = 1;
if (LOG_RMC_FIXONLY) {
if (!fix) {
Serial.print('_', BYTE);
bufferidx = 0;
return;
// rad. lets log it!
Serial.print('#', BYTE);
digitalWrite(led2Pin, HIGH); // sets the digital pin as output
if(card.write_file(f, (uint8_t *) buffer, bufferidx) != bufferidx) {
putstring_nl("can't write!");
return;
bufferidx = 0;
// turn off GPS module?
if (TURNOFFGPS) {
digitalWrite(powerPin, HIGH);
sleep_sec(SLEEPDELAY);
return;
bufferidx++;
if (bufferidx == BUFFSIZE-1) {
Serial.print('!', BYTE);
bufferidx = 0;
void sleep_sec(uint8_t x) {
while (x--) {
// set the WDT to wake us up!
WDTCSR |= (1 << WDCE) | (1 << WDE); // enable watchdog & enable changing it
WDTCSR = (1<< WDE) | (1 <<WDP2) | (1 << WDP1);
WDTCSR |= (1<< WDIE);
set_sleep_mode(SLEEP_MODE_PWR_DOWN);
sleep_enable();
sleep_mode();
sleep_disable();
SIGNAL(WDT_vect) {
WDTCSR = 0;
/* End code */
Bump
i have same problem
