Hi everyone, i was wondering if it is possible to do polygon algorithm 2x, meaning a box within a box. I found this website GPS Dog Fence | Hackaday.io i can modify to my board and gps module or is it possible to set it up like if the dog gets 5ft from the fence it starts beeping, like how wired fencing is.
Of course it is. The point of interest (the dog) is in a box, or it isn't. If you know whether in-a-box means that the dog is where it belongs, or not, then you know whether the dog is where it belongs, or not.
If the two boxes represent the yard and the rose garden, and the dog is in both boxes, the roses are in danger. If the dog is in the yard but not in the rose garden, the roses are safe (from the dog).
this is the code so far, I cant figure out how to input the 2nd set of grid cords.
l ______________ l
l l l l
l l /\ l l
l l l_l l l
l l______________l l
l_________________l
#include <TinyGPS++.h>
#include <SoftwareSerial.h> // Include software serial library
#define S_RX 4 // Define software serial RX pin
#define S_TX 3 // Define software serial TX pin
#define D7 7 // pinmode number 7
#define buzzer 8 // pinmode number 8
TinyGPSPlus gps;
bool sat_connection = false;
double lat,lon;
bool c;
int i,j;
long unsigned fix_age;
long unsigned sat;
int count1 = 0;
int count2 = 0;
double latitude[100] = {XX.xxxxxx, XX.xxxxxx, XX.xxxxxx, XX.xxxxxx}; // Insert at least 4 latitude coordinates (Do not put your first coordinate again at the end to complete the polygon, the algorithm does this for you)
double longitude[100] = {XX.xxxxxx, XX.xxxxxx, XX.xxxxxx, XX.xxxxxx}; // and their matching longitude points
int numPoints = 4; // Put the number of latitude and longitude pairs you used here
SoftwareSerial SoftSerial(S_RX, S_TX); // Configure SoftSerial library
SoftSerial.begin(4800);
pinMode(D7,OUTPUT); // setup the pin used to turn on collar trigger circuit
pinMode(Buzzer,OUTPUT); // setup the pin used to turn on collar buzzer circit
while (SoftSerial.available() > 0) {
gps.encode(SoftSerial.read());
lat = gps.location.rawLat().billionths;
lon = gps.location.rawLng().billionths;
lat = gps.location.lat(), 8;
lon = gps.location.lng(), 8;
// display position
Serial.print("Position: ");
Serial.print("lat: ");Serial.print(lat);Serial.print(" ");// print latitude
Serial.print("lon: ");Serial.println(lon);// print longitude
sat = gps.satellites.value();
Serial.print("Num Satelites: ");Serial.println(sat);
double testx = lon;
double testy = lat;
Serial.print("testx = ");
Serial.print(testx, 8);
Serial.print("\n");
Serial.print("testy = ");
Serial.print(testy, 8);
Serial.print("\n");
c = false;
for (i = 0, j = numPoints-1; i < numPoints; j = i++) {
Serial.print("latitude[i] = ");
Serial.print(latitude[i], 8);
Serial.print("\n");
Serial.print("latitude[j] = ");
Serial.print(latitude[j], 8);
Serial.print("\n");
Serial.print("longitude[i] = ");
Serial.print(longitude[i], 8);
Serial.print("\n");
Serial.print("longitude[j] = ");
Serial.print(longitude[j], 8);
Serial.print("\n");
// BELOW IS THE POINT IN POLYGON ALGORITHM. I COMPLETELY BORROWED THIS CODE, BUT IT WORKS.
if ( ((latitude[i]>testy) != (latitude[j]>testy)) &&
(testx < (longitude[j]-longitude[i]) * (testy-latitude[i]) / (latitude[j]-latitude[i]) + longitude[i]) ){
c = !c;
Serial.print("is this happening?");
if ((sat_connection == true) && (c == false)){
Serial.print("Outside Fence \n");
if (count1 == 0){
count1 = 1;
if (count2 == 0){
digitalWrite(D7,HIGH);
else if (count2 == 1){
digitalWrite(D7,LOW);
if ((sat_connection == false) || (c == true)){
Serial.print("Inside Fence \n");
if (c ==true){
count1 = 0;
count2 = 0;
No sense in declaring arrays to be of length 100, when you are storing only four points.
Drop the ", 8" as seen below. It is used (nonsensically in this case) with Serial.print().
Hint: First, just get a basic program running that demonstrates correct use of the polygon routine, and verify that it gives the correct results for a point inside or outside the polygon. When you finally and completely understand how it works, add the GPS stuff later.
The second set is inter perimeter will turn on the buzzer, the first set is outer perimeter will turn on the shocker. Im not using the Particle Electron & Copernicus II GPS like the original code is intended for. Serial.print is in the original code, i can post it if you would like
