GPS data is not changing
Hi
I’m using Arduino Uno Board with NEO6 GPS Module.
I got nice raw NMEA codes (see image below).
But when I test DeviceExample, it returns the following error.
Here is the code;
#include <TinyGPS++.h>
#include <SoftwareSerial.h>
   This sample sketch demonstrates the normal use of a TinyGPS++ (TinyGPSPlus) object.
   It requires the use of SoftwareSerial, and assumes that you have a
   4800-baud serial GPS device hooked up on pins 4(rx) and 3(tx).
static const int RXPin = 4, TXPin = 3;
static const uint32_t GPSBaud = 4800;
// The TinyGPS++ object
TinyGPSPlus gps;
// The serial connection to the GPS device
SoftwareSerial ss(RXPin, TXPin);
  ss.begin(GPSBaud);
  Serial.println(F("DeviceExample.ino"));
  Serial.println(F("A simple demonstration of TinyGPS++ with an attached GPS module"));
  Serial.print(F("Testing TinyGPS++ library v. ")); Serial.println(TinyGPSPlus::libraryVersion());
  Serial.println(F("by Mikal Hart"));
  // This sketch displays information every time a new sentence is correctly encoded.
  while (ss.available() > 0)
    if (gps.encode(ss.read()))
      displayInfo();
  if (millis() > 5000 && gps.charsProcessed() < 10)
    Serial.println(F("No GPS detected: check wiring."));
    while(true);
void displayInfo()
  Serial.print(F("Location: "));
  if (gps.location.isValid())
    Serial.print(gps.location.lat(), 6);
    Serial.print(F(","));
    Serial.print(gps.location.lng(), 6);
    Serial.print(F("INVALID"));
  Serial.print(F("  Date/Time: "));
  if (gps.date.isValid())
    Serial.print(gps.date.month());
    Serial.print(F("/"));
    Serial.print(gps.date.day());
    Serial.print(gps.date.year());
  Serial.print(F(" "));
  if (gps.time.isValid())
    if (gps.time.hour() < 10) Serial.print(F("0"));
    Serial.print(gps.time.hour());
    Serial.print(F(":"));
    if (gps.time.minute() < 10) Serial.print(F("0"));
    Serial.print(gps.time.minute());
    if (gps.time.second() < 10) Serial.print(F("0"));
    Serial.print(gps.time.second());
    Serial.print(F("."));
    if (gps.time.centisecond() < 10) Serial.print(F("0"));
    Serial.print(gps.time.centisecond());
The default baudrate for that model seems to be 9600 baud. Have you tried that?
Hi Shannon,
Thanks, It’s working very nicely. However, when I try with the nodeMCU board. It returns the error. There I was using default baud rate [9600]. Here is the code
#define BLYNK_PRINT Serial
#include <ESP8266WiFi.h>
#include <BlynkSimpleEsp8266.h>
static const int RXPin = 4, TXPin = 5;   // GPIO 4=D2(conneect Tx of GPS) and GPIO 5=D1(Connect Rx of GPS
static const uint32_t GPSBaud = 9600; //if Baud rate 9600 didn't work in your case then use 4800
TinyGPSPlus gps; // The TinyGPS++ object
WidgetMap myMap(V0);  // V0 for virtual pin of Map Widget
SoftwareSerial ss(RXPin, TXPin);  // The serial connection to the GPS device
BlynkTimer timer;
float spd;       //Variable  to store the speed
float sats;      //Variable to store no. of satellites response
String bearing;  //Variable to store orientation or direction of GPS
char auth[] = "b2KtdXdyyP9p-kOZh_AkeZd8ldh_BpWZ";              //Your Project authentication key
char ssid[] = "Linksys";                                       // Name of your network (HotSpot or Router name)
char pass[] = "123456789";                                      // Corresponding Password
//unsigned int move_index;         // moving index, to be used later
unsigned int move_index = 1;       // fixed location for now
  ss.begin(GPSBaud);
  Blynk.begin(auth, ssid, pass);
  timer.setInterval(5000L, checkGPS); // every 5s check if GPS is connected, only really needs to be done once
void checkGPS(){
  if (gps.charsProcessed() < 10)
      Blynk.virtualWrite(V4, "GPS ERROR");  // Value Display widget  on V4 if GPS not detected
      // sketch displays information every time a new sentence is correctly encoded.
        displayInfo();
  Blynk.run();
  timer.run();
void displayInfo()
  if (gps.location.isValid() )
    float latitude = (gps.location.lat());     //Storing the Lat. and Lon.
    float longitude = (gps.location.lng());
    Serial.print("LAT:  ");
    Serial.println(latitude, 6);  // float to x decimal places
    Serial.print("LONG: ");
    Serial.println(longitude, 6);
    Blynk.virtualWrite(V1, String(latitude, 6));
    Blynk.virtualWrite(V2, String(longitude, 6));
    myMap.location(move_index, latitude, longitude, "GPS_Location");
    spd = gps.speed.kmph();               //get speed
       Blynk.virtualWrite(V3, spd);
       sats = gps.satellites.value();    //get number of satellites
       Blynk.virtualWrite(V4, sats);
       bearing = TinyGPSPlus::cardinal(gps.course.value()); // get the direction
       Blynk.virtualWrite(V5, bearing);
Thanks, It's working very nicely. However, when I try with the nodeMCU board. It returns the error. There I was using default baud rate [9600]. Here is the code
You tell us different things with every post. If you changed the baudrate to 4800 baud to let it work on the UNO why do you use the default baudrate again on the nodeMCU? And why are you asking for the UNO if the problem is on the nodeMCU?
This means that the GPS unit does not have a satellite fix.
Take the setup outside, to where you have a clear view of the sky. If the GPS module is new, you may have to wait up to 15 minutes for a "cold start" fix.
