Hello everyone,
I made a GPS data logger with my custom design Arduino board,where it logs data like Latitude,Longitude,Time & date etc., in to a micro SD card, it's working fine when I connected it with the computer supply and watching the Serial monitor.
but when I remove all the connection with my Arduino UNO and supplied power using battery then it's not starting up at all.
what should be the problem.?
is the problem with Serial commands used in my code.? Shall I remove all of them and give a try.?
I also tried using a Diode from 3.3V to RX pin on the Atmega328p on my custom design board and it's working like a charm.
Hello @J-M-L thank you for the reply, I am using additional Arduino UNO board without atmega328P IC board, Connecting Rx of my custom board to Rx of Arduino UNO and Tx to Tx and uploading the code, meanwhile I am using 5V from the Arduino UNO and also ground lines from it.
Hi TOM,
Thank you very much for the reply, I made few images please check with the comment.
First picture is the block diagram where I am using to upload the code and watching the serial monitor and it’s working fine (Note : No battery is connected)
Second picture is the block diagram where I am removing the Arduino UNO and connecting the Power lines to the 3.7V to 5V step up converter, I am connecting battery to this converter.
third picture is the block diagram which shows adding a diode in between 5V to Rx or Tx of Custom design board.
