I have a rover with a Mega, a LSM303 compass and Adafruits Ultimate GPS module. I can control it with a transmitter with 2 joysticks connected to a UNO and they communicate via xbee wifi modules. If I disable the call to read the GPS it works fine, when I enable the read GPS function I get two problems. The motors will pulse on for a couple of seconds then off for a few seconds. There is also about a 5 to 10 second delay of the control I am sending from the transmitter. I’m sure there’s a better way to do it but I’ve added delays in the calls to the compass and GPS routines. I reset a timer, at 500 milliseconds I call the compass, at 1500 milliseconds I call the GPS, timer is reset at 3000 milliseconds. I’ve played around with the times but it doesn’t help. The compass and GPS functions are on separate tabs. I couldn’t post all of the main sketch, I exceeded the word limit. So I’ve attached the main sketch as an attachment. I was able to attached the wifi control from the transmitter, in case the GPS is interfering with that, and the GPS read function.
WiFi control
[code]
// Control Rover from Wifi transmitter
void Wifi_Cntrl() {
// Throttle_Ref used for forward and backward control
if (Throttle_Ref < 470) {
// Set Motor A backward
digitalWrite(in1, HIGH);
digitalWrite(in2, LOW);
// Set Motor B backward
digitalWrite(in3, HIGH);
digitalWrite(in4, LOW);
// Convert the declining Throttle_Ref readings for going backward from 470 to 0 into 0 to 255 value for the PWM signal for increasing the motor speed
motorSpeedA = map(Throttle_Ref, 470, 0, 0, motorSpeedASet);
motorSpeedB = map(Throttle_Ref, 470, 0, 0, motorSpeedBSet);
Serial.print("Reverse"); Serial.print(","); Serial.print(motorSpeedA); Serial.print(","); Serial.println(motorSpeedB);
else if (Throttle_Ref > 550) {
// Set Motor A forward
digitalWrite(in1, LOW);
digitalWrite(in2, HIGH);
// Set Motor B forward
digitalWrite(in3, LOW);
digitalWrite(in4, HIGH);
// Convert the increasing Throttle_Ref readings for going forward from 100 to 1023 into 0 to 255 value for the PWM signal for increasing the motor speed
motorSpeedA = map(Throttle_Ref, 550, 1023, 0, motorSpeedASet);
motorSpeedB = map(Throttle_Ref, 550, 1023, 0, motorSpeedBSet);
Serial.print("Forward"); Serial.print(","); Serial.print(motorSpeedA); Serial.print(","); Serial.println(motorSpeedB);
// If joystick stays in middle the motors are not moving
else {
motorSpeedA = 0;
motorSpeedB = 0;
// Steering_Ref used for left and right control
if (Steering_Ref < 470) {
motorSpeedA = map(Steering_Ref, 470, 0, 0, motorSpeedASet);
motorSpeedB = map(Steering_Ref, 470, 0, 0, motorSpeedBSet);
Serial.print("Right"); Serial.print(","); Serial.print(motorSpeedA); Serial.print(","); Serial.println(motorSpeedB);
// Confine the range from 0 to 255
if (motorSpeedA < 0) {
motorSpeedA = 0;
if (motorSpeedB < 0) {
motorSpeedB = 0;
if (motorSpeedA > motorSpeedASet) {
motorSpeedA = motorSpeedASet;
if (motorSpeedB > motorSpeedBSet) {
motorSpeedB = motorSpeedBSet;
if (Steering_Ref > 550) {
motorSpeedA = map(Steering_Ref, 550, 1023, 0, motorSpeedASet);
motorSpeedB = map(Steering_Ref, 550, 1023, 0, motorSpeedBSet);
Serial.print("Left"); Serial.print(","); Serial.print(motorSpeedA); Serial.print(","); Serial.println(motorSpeedB);
motorSpeedA = 0;
motorSpeedB = 0;
// Prevent buzzing at low speeds (Adjust according to your motors. My motors couldn't start moving if PWM value was below value of 70)
if (motorSpeedA < 70) {
motorSpeedA = 0;
if (motorSpeedB < 70) {
motorSpeedB = 0;
analogWrite(enA, motorSpeedA); // Send PWM signal to motor A
analogWrite(enB, motorSpeedB); // Send PWM signal to motor B
} // end void Wifi_Cntrl
[/code]
GPS Sketch
[code]
void readGPS() {
clearGPS();
while (!GPS.newNMEAreceived()) { //Loop until you have a good NMEA sentence
c = GPS.read();
GPS.parse(GPS.lastNMEA()); //Parse that last good NMEA sentence
NMEA1 = GPS.lastNMEA();
c = GPS.read();
NMEA2 = GPS.lastNMEA();
// Serial.println(NMEA1);
// Serial.println(NMEA2);
// Serial.println("");
} // end readGPS
void clearGPS() { //Clear old and corrupt data from serial port
c = GPS.read();
c = GPS.read();
c = GPS.read();
} // end clearGPS
[/code]
Thanks
John
Rover2_Phase6.ino (9.77 KB)
