GPS L80-M39 no satellites
I have connected an L80-M39 to my ESP32. I think i can communicate correctly with the GPS module but whatever i do, it cannot get any satellite information.
This is the raw result:
$GPRMC,000528.800,V,,,,,0.00,0.00,050180,,,N*46
$GPVTG,0.00,T,,M,0.00,N,0.00,K,N*32
$GPGGA,000528.800,,,,,0,0,,,M,,M,,*4F
$GPGSA,A,1,,,,,,,,,,,,,,,*1E
$GPGSV,1,1,00*79
$GPGLL,,,,,000528.800,V,N*7D
$GPTXT,01,01,02,ANTSTATUS=OPEN*2B
This is the code i am using:
#include <TinyGPS++.h>                           //get library here > http://arduiniana.org/libraries/tinygpsplus/
TinyGPSPlus gps;                                 //create the TinyGPS++ object
  Serial.begin(115200);                       //setup Serial monitor ouput
  Serial1.begin(9600, SERIAL_8N1, 13, 12);    //start Serial for GPS at defined baud rate
float GPSLat;                                     //Latitude from GPS
float GPSLon;                                     //Longitude from GPS
float GPSAlt;                                     //Altitude from GPS
uint8_t GPSSats;                                  //number of GPS satellites in use
uint32_t GPSHdop;                                 //HDOP from GPS
uint32_t GPSstarttimemS;                          //time in mS when GPS is scanned fo fix
uint32_t GPSendtimemS;                            //time in mS when GPS got a fix
  gpsWaitFix();
  displayGPSfix();
  Serial.println("");
void gpsWaitFix()
  //waits till the GPS gets an updated fix
  uint8_t GPSchar;
  Serial.println(F("Wait for updated GPS Fix"));
  GPSstarttimemS = millis();
  while (1)
    if (Serial1.available() > 0)
      GPSchar = Serial1.read();
      gps.encode(GPSchar);
      Serial.write(GPSchar);
    if (gps.location.isUpdated() && gps.altitude.isUpdated())
      GPSendtimemS = millis();
void displayGPSfix()
  float tempfloat;
  Serial.print(F("New GPS Fix "));
  Serial.print(GPSendtimemS - GPSstarttimemS);
  Serial.print(F("mS  "));
  GPSLat = gps.location.lat();
  GPSLon = gps.location.lng();
  GPSAlt = gps.altitude.meters();
  GPSSats = gps.satellites.value();
  GPSHdop = gps.hdop.value();
  tempfloat = ( (float) GPSHdop / 100);
  Serial.print(F("Lat,"));
  Serial.print(GPSLat, 6);
  Serial.print(F(",Lon,"));
  Serial.print(GPSLon, 6);
  Serial.print(F(",Alt,"));
  Serial.print(GPSAlt, 1);
  Serial.print(F("m,Sats,"));
  Serial.print(GPSSats);
  Serial.print(F(",HDOP,"));
  Serial.print(tempfloat, 2);
I assume the communication is okay since i do get results from the gps module?
The module is put in front of the window with the label up
Can the GPS receiver also see GPS satellites or only the ceiling of the room?
I don't know exactly how the view is, but does it need to exactly see the sky? The module eventually will be installed in a motorhome but under the roof. Will this work?
Check it simply.
I don't understand why it works so bad. After half an our I was able to get 3 or 4 satellites but the GPS modules needed to be sticked to the window of the house.
In the motorhome is already a cheap GPS tracker built in which is not located close to a window and it does get GPS really quickly.
Now after restarting and waiting for 15 minutes already, it still has no gps signal and still 0 satellites found
Still struggling to get signal. I have placed the module outside with the top up and it does get time but still 0 satellites
I tested a Quectel L80 back in 2020, nice compact, good performing GPS.
Outside in my garden with a view of the sky it got a fix from cold in 40 seconds, which is as expected really.
