Try to avoid using serial prints while your expecting characters to be received from the GPS, this is very important especially when using software serial.
A more reliable way to read the GPS is shown below. The read of the GPS is called from loop() with a timeout. When the gpsWaitFix() returns true, you can then print stuff, do calculations etc.
The gpsWaitFix() function thats reading the GPS is kept lean to minimise the risk of upsetting softwareserial.
Programs for Arduino - Copyright of the author Stuart Robinson - 23/03/23
This program is supplied as is, it is up to the user of the program to decide if the program is
suitable for the intended purpose and free from errors.
Program Operation - This program is a portable GPS checker. It reads the GPS for 5 seconds and copies
the characters from the GPS to the serial monitor.
Serial monitor baud rate is set at 115200.
#include <TinyGPS++.h> //get library here > http://arduiniana.org/libraries/tinygpsplus/
TinyGPSPlus gps; //create the TinyGPS++ object
#define RXpin A3 //pin number for GPS RX input into Arduino - TX from GPS
#define TXpin A2 //pin number for GPS TX output from Arduino- RX into GPS
#define LED1 8 //pin number for LED, turns on when printing Fix data
#include <SoftwareSerial.h>
SoftwareSerial GPSserial(RXpin, TXpin);
float GPSLat; //Latitude from GPS
float GPSLon; //Longitude from GPS
float GPSAlt; //Altitude from GPS
uint8_t GPSSats; //number of GPS satellites in use
uint32_t GPSHdop; //HDOP from GPS
uint8_t hours, mins, secs, day, month;
uint16_t year;
uint32_t startGetFixmS;
uint32_t endFixmS;
//GPS test co-ordinates to use for distance and direction calculatio
const float TestLatitude = 51.50807; //Tower of London
const float TestLongitude = -0.07606;
if (gpsWaitFix(5))
digitalWrite(LED1, HIGH); //LED on to indicate fix
Serial.print(F("Fix time "));
Serial.print(endFixmS - startGetFixmS);
Serial.println(F("mS"));
GPSLat = gps.location.lat();
GPSLon = gps.location.lng();
GPSAlt = gps.altitude.meters();
GPSSats = gps.satellites.value();
GPSHdop = gps.hdop.value();
hours = gps.time.hour();
mins = gps.time.minute();
secs = gps.time.second();
day = gps.date.day();
month = gps.date.month();
year = gps.date.year();
printGPSfix();
startGetFixmS = millis(); //have a fix, next thing that happens is checking for a fix, so restart timer
digitalWrite(LED1, LOW);
Serial.print(F("Timeout - No GPS Fix "));
Serial.print( (millis() - startGetFixmS) / 1000 );
Serial.println(F("s"));
bool gpsWaitFix(uint16_t waitSecs)
//waits a specified number of seconds for a fix, returns true for updated fix
uint32_t startmS, waitmS;
uint8_t GPSchar;
Serial.print(F("Wait GPS Fix "));
Serial.print(waitSecs);
Serial.println(F(" seconds"));
waitmS = waitSecs * 1000; //convert seconds wait into mS
startmS = millis();
while ( (uint32_t) (millis() - startmS) < waitmS) //allows for millis() overflow
if (GPSserial.available() > 0)
GPSchar = GPSserial.read();
gps.encode(GPSchar);
Serial.write(GPSchar);
if (gps.speed.isUpdated() && gps.satellites.isUpdated()) //ensures that GGA and RMC sentences have been received
endFixmS = millis(); //record the time when we got a GPS fix
return true;
return false;
void printGPSfix()
float tempfloat;
uint32_t distance;
uint16_t direction;
Serial.print(F("New GPS Fix "));
tempfloat = ( (float) GPSHdop / 100);
Serial.print(F("Lat,"));
Serial.print(GPSLat, 6);
Serial.print(F(",Lon,"));
Serial.print(GPSLon, 6);
Serial.print(F(",Alt,"));
Serial.print(GPSAlt, 1);
Serial.print(F("m,Sats,"));
Serial.print(GPSSats);
Serial.print(F(",HDOP,"));
Serial.print(tempfloat, 2);
Serial.print(F(",Time,"));
if (hours < 10)
Serial.print(F("0"));
Serial.print(hours);
Serial.print(F(":"));
if (mins < 10)
Serial.print(mins);
if (secs < 10)
Serial.print(secs);
Serial.print(F(",Date,"));
Serial.print(day);
Serial.print(F("/"));
Serial.print(month);
Serial.print(year);
distance = gps.distanceBetween(GPSLat, GPSLon, TestLatitude, TestLongitude);
direction = gps.courseTo(GPSLat, GPSLon, TestLatitude, TestLongitude);
Serial.print(F("Distance to Test Location ("));
Serial.print(TestLatitude, 6);
Serial.print((","));
Serial.print(TestLongitude, 6);
Serial.print((") "));
Serial.print(distance);
Serial.print(("m"));
Serial.print(F("Direction to Test Location ("));
Serial.print(direction);
Serial.print(("d"));
pinMode(LED1, OUTPUT);
GPSserial.begin(9600);
Serial.print(F(__FILE__));
Serial.println(F("GPS Checker Starting"));
