Hi everyone, I have a little proyect for making a gps logger, so far I have set the venus gps at 10hz and I succesfull meke a sketch for log the information to a sd shiel. However it has a little problem, sometimes it logs the information with strange characters.
Here es the sketch.
#include <SD.h>
#include <Wire.h>
#include <SoftwareSerial.h>
#include "I2Cdev.h"
#include "MPU6050.h"
SoftwareSerial gpsSerial(6, 5); // RX, TX (TX not used)
const int sentenceSize = 312;
MPU6050 accelgyro;
int16_t ax, ay, az;
int16_t gx, gy, gz;
char sentence[sentenceSize];
#define LOG_INTERVAL 100
const int chipSelect = 10;
File logfile;
long idd = 0;
long ids = 0;
long idm = 0;
long idh = 0;
void error(char *str)
Serial.print("error: ");
Serial.println(str);
while(1);
Wire.begin();
Serial.begin(38400);
gpsSerial.begin(38400);
Serial.println("Iniciando MPU");
accelgyro.initialize();
Serial.println("Iniciando SD");
// make sure that the default chip select pin is set to
// output, even if you don't use it:
pinMode(10, OUTPUT);
// see if the card is present and can be initialized:
if (!SD.begin(chipSelect)) {
Serial.println("Fallo de SD");
return;
Serial.println("Inicio Correcto");
Serial.println("Testeando MPU");
Serial.println(accelgyro.testConnection() ? "Conexion MPU6050 exitosa" : "Error de Conexion a MPU");
// create a new file
char filename[] = "LOGGER00.CSV";
for (uint8_t i = 0; i < 100; i++) {
filename[6] = i/10 + '0';
filename[7] = i%10 + '0';
if (! SD.exists(filename)) {
// only open a new file if it doesn't exist
logfile = SD.open(filename, FILE_WRITE);
break; // leave the loop!
if (! logfile) {
error("couldnt create file");
Serial.print("Logging to: ");
Serial.println(filename);
static int i = 0;
if (gpsSerial.available())
char ch = gpsSerial.read();
if (ch != '\n' && i < sentenceSize)
sentence[i] = ch;
i++;
sentence[i] = '\0';
i = 0;
char field[20];
getField(field, 0);
accelgyro.getMotion6(&ax, &ay, &az, &gx, &gy, &gz);
if (strcmp(field, "$GPRMC") == 0)
Serial.print("Tiempo: ");
getField(field, 1);
Serial.print(field);
logfile.print(field);
logfile.print("\t");
Serial.print("Lat: ");
getField(field, 3); // number
Serial.print("Long: ");
getField(field, 5); // number
Serial.print("Velocidad: ");
getField(field, 7);
Serial.print("a/g:\t");
Serial.print(ax); Serial.print("\t");
logfile.print(ax);
Serial.print(ay); Serial.print("\t");
logfile.print(ay);
Serial.print(az); Serial.print("\t");
logfile.print(az);
Serial.print(gx); Serial.print("\t");
logfile.print(gx);
Serial.print(gy); Serial.print("\t");
logfile.print(gy);
Serial.println(gz);
logfile.println(gz);
logfile.flush();
void getField(char* buffer, int index)
int sentencePos = 0;
int fieldPos = 0;
int commaCount = 0;
while (sentencePos < sentenceSize)
if (sentence[sentencePos] == ',')
commaCount ++;
sentencePos ++;
if (commaCount == index)
buffer[fieldPos] = sentence[sentencePos];
fieldPos ++;
sentencePos ++;
buffer[fieldPos] = '\0';
Now changing this value in the line // const int sentenceSize = 312; the sketch woks better or worse according that value, nontheless it always log in some point a line of data with strange characters.
Like this
115948.000 2400.0000 12100.0000 000.0-5948 2372 -15384 -266 70 -1
115948.200 24˜0.0000 12100.0000 000.0-6132 2260 -15532 -235 35 -4
The second line has a weir character there, it happens, according to the value, more or less often.
There is anyone who can help with this glitch?
