GPS Logger - no GPS data.
As advised, I have checked the wiring and tried the setup outside in the open. I have also stripped the programme of redundant code, or code that prettified the serial output. This helped me see relationships within the programme more clearly than before; however, I can't seem to get a GPS on the serial monitor [invalid,invalid,invalid,invalid] or the SD card [invalid,invalid,invalid,invalid].
Information on my hardware and pinning are set out below:
Hardware.
Arduina Mega 2560
5v ready Micro-SD \breakout Board
HAB Supplies UBlox 7 with Santana Ariel (gets signal on other programmes)
Pin arrangement
SD = CS-53; DI-51; DO-50; CLK-52; 5v-5v; GND-GND (this unit works)
GPS = TX-RX(serial1(pin19)); RX-TX(serial1(pin18)); GND-GND; 5v-5v; EN-5v.
My reduced programme follows - any help would be appreciated (I hope my use of the code button for the text below meets the Forum requirements ).
//TinyGPS Library and Helper Functions by Mikal Hart http://arduiniana.org/libraries/tinygps/
#include <TinyGPS.h>
#include <SD.h>
#include <stdlib.h>
#include <SPI.h>
/* Code demonstrates the normal use of a TinyGPS object.
   It uses an Arduino Mega with a GPS attached to Serial1 at 4800 buad.
TinyGPS gps;
static char dtostrfbuffer[20];
int CS = 53;
int LED = 13;
//Define String
String SD_date_time = "invalid";
String SD_lat = "invalid";
String SD_lon = "invalid";
String SD_alt = "invalid";
String dataString = ""; ////////////////////////////datastring
static void gpsdump(TinyGPS &gps);
static bool feedgps();
static void print_float(float val, float invalid, int len, int prec, int SD_val);/////////////////Float
static void print_int(unsigned long val, unsigned long invalid, int len);
static void print_date(TinyGPS &gps);
static void print_str(const char *str, int len);
  pinMode(CS, OUTPUT);  //Chip Select for the SD Card
  pinMode(LED, OUTPUT);  //LED Indicator
  //Serial interfaces
  Serial1.begin(4800);
  //Connect to the SD Card
  if (!SD.begin(CS))
    Serial.println("Card Failure");
    return;
  bool newdata = false;
  unsigned long start = millis();
  // Every second print an update
  while (millis() - start < 2000);
    if (feedgps())
      newdata = true;
  gpsdump(gps);
  //Write the newest information to the SD Card
  dataString = SD_date_time + "," + SD_lat + "," + SD_lon + "," + SD_alt;
  if (SD_date_time != "invalid")
    digitalWrite(LED, HIGH);
    digitalWrite(LED, LOW);
  delay(5);
  //Open the Data CSV File
  File dataFile = SD.open("LOG.csv", FILE_WRITE);
  if (dataFile)
    dataFile.println(dataString);
    Serial.println(dataString);
    dataFile.close();
    delay(10);
    Serial1.println("\nCouldn't open the log file!");
  float flat, flon;
  unsigned long age, date, time, chars = 0;
  unsigned short sentences = 0, failed = 0;
  static const float LONDON_LAT = 51.508131, LONDON_LON = -0.128002;
  print_int(gps.satellites(), TinyGPS::GPS_INVALID_SATELLITES, 5);
  print_int(gps.hdop(), TinyGPS::GPS_INVALID_HDOP, 5);
  gps.f_get_position(&flat, &flon, &age);
  print_float(flat, TinyGPS::GPS_INVALID_F_ANGLE, 9, 5, 1); //LATITUDE
  print_float(flon, TinyGPS::GPS_INVALID_F_ANGLE, 10, 5, 2); //LONGITUDE
  print_int(age, TinyGPS::GPS_INVALID_AGE, 5);
  print_date(gps); //DATE AND TIME
  print_float(gps.f_altitude(), TinyGPS::GPS_INVALID_F_ALTITUDE, 8, 2, 3);//ALTITUDE
  //  print_float(gps.f_course(), TinyGPS::GPS_INVALID_F_ANGLE, 7, 2, 0);
  //  print_float(gps.f_speed_kmph(), TinyGPS::GPS_INVALID_F_SPEED, 6, 2, 0);
  //  print_str(gps.f_course() == TinyGPS::GPS_INVALID_F_ANGLE ? "*** " : TinyGPS::cardinal(gps.f_course()), 6);
  //  print_int(flat == TinyGPS::GPS_INVALID_F_ANGLE ? 0UL : (unsigned long)TinyGPS::distance_between(flat, flon, LONDON_LAT, LONDON_LON) / 1000, 0xFFFFFFFF, 9);
  //  print_float(flat == TinyGPS::GPS_INVALID_F_ANGLE ? 0.0 : TinyGPS::course_to(flat, flon, 51.508131, -0.128002), TinyGPS::GPS_INVALID_F_ANGLE, 7, 2, 0);
  //  print_str(flat == TinyGPS::GPS_INVALID_F_ANGLE ? "*** " : TinyGPS::cardinal(TinyGPS::course_to(flat, flon, LONDON_LAT, LONDON_LON)), 6);
  //  gps.stats(&chars, &sentences, &failed);
  //  print_int(chars, 0xFFFFFFFF, 6);
  //  print_int(sentences, 0xFFFFFFFF, 10);
  //  print_int(failed, 0xFFFFFFFF, 9);
  Serial1.println();
  delay(10);
  char sz[32];
  Serial1.print(sz);//serial1 removes gbldgok
  feedgps();
  char sz[32];
  if (val == invalid)
    strcpy(sz, "*******");
    sz[len] = 0;
    Serial1.print(val, prec);
    delay(10);
  feedgps();
  while (Serial1.available())
    if (gps.encode(Serial1.read()))
      return true;
  return false;
Regards,
Colin.
Where in the program do the SD variables such as SD_date_time get set to anything but "invalid" ?
Thanks for the reply.
No, I just get 'invalid'
Again,
Thanks for getting back.
Colin.
Sorry, in my excitement I misread your note. Should I set those variables (SD_date_time) to something? My apologies, I am very much a novice - but improving, nevertheless.
Colin.
Your first step should be to load a sketch that just echoes the raw NMEA sentences to the serial monitor. Then you can be sure that the GPS unit is working and that the Arduino is getting valid data from it.
If you want to output anything but "invalid" then yes. Look at the TinyGPS examples to see how the data is retrieved from the GPS unit.
Thanks aarg.
I have just tried the Simple TinyGPS library v. 12, and while in the garden got the following on my Mega 2560:
"CHARS=0 SENTENCES=0 CSUM ERR=0
CHARS=0 SENTENCES=0 CSUM ERR=0"
Then I tried it again on my Uno, with the same result
Thanks for the prompt.
Any suggestions on the GPS aspect of the problem, aarg?
Thanks also UKHeliBob
I shall follow up the Tiny retrieval example. There is a simple solution, I m sure, but the problem doesn't seem too simple or straight forward for me at the moment!
Best wishes,
Colin.
This is not a 5V GPS module.
