GPS Module GY-GPS6MV2 don't receive GPS coordenates (TinyGPS Library)
Hi there :wink:
I bought recently a GPS serial module GY-GPS6MV2 to make some expermients…
This module work with the library TinyGPS :
It seems to be comunication between the arduino and the GPS module but the I don’t receive GPS coordenates… :confused:
I followed this tutorial :
After 1 minut, the led of the GPS module is blinking.
Now I saw this problem : The battery of the GPS module is unsoldered…
Using this code I think I receive the GMT hour…
#include <SoftwareSerial.h>
SoftwareSerial gps(4,3);
char dato=' ';
 gps.begin(9600);
  if(gps.available())
    dato=gps.read();
    Serial.print(dato);
I tried to power the GPS module with and external 3.7 battery, I tried to put the system outdoor but without sucess…
Do you think is the problem here? Is there a solution to “reprogram” the delault configuration of the GPS module after resolding the battery?
Info : I’m living in Mexico, so no problem for GPS signal?
Thanks for your help.
Regards :wink:
PD : the GPS module seems to work, I tested it with u-center and I get the results :slight_smile: Now I have to get it working with arduino…
What does UCenter use for the GPS baud rate?
Hi there!
TinyGPS and de TinyGPS++ libraries are using a 4800bps software serial connection.
With u-center, the module is connected at 9600.
I modified the speed of the sofwareserial to 9600 and it works!
Now comes THE QUESTION...
How I can force the GY-GPS6MV2 to work at 4800bps? (using u-center?)
Regards :) 8)
The module documentation will explain that.
|500x338
Yes but how I can do it? I have to send serial commands? This data is saved into the EEPROM of the module?
Regards.
No. [u]Read[/u] the information that you posted.
|453x500
OK Correct. So pins are hardware connection? PIN 14&15?
Hi, Axxel. It seems we've gone through the same issue. I have fixed it reviewing the RX/TX pins. Not all pins are suitable, it depends on your board. Take a look at: https://www.arduino.cc/en/Reference/softwareSerial Hope it helps!
