Hey everyone, I have a GPS module that I have working and printing out the data to the serial monitor that is accurate. What I am trying to do now is parse that data using the TinyGPS library that is explained here: TinyGPS | Arduiniana
Here is my code:
#if (ARDUINO >= 100)
#include <SoftwareSerial.h>
SoftwareSerial mySerial(2, 3);
#else
// If you're using Arduino IDE v23 or earlier, you'll
// need to install NewSoftSerial
#include <NewSoftwareSerial.h>
NewSoftwareSerial mySerial(2, 3);
#endif
#include "TinyGPS.h"
TinyGPS gps;
#define PMTK_SET_NMEA_UPDATE_1HZ "$PMTK220,1000*1F"
#define PMTK_SET_NMEA_UPDATE_5HZ "$PMTK220,200*2C"
#define PMTK_SET_NMEA_OUTPUT_RMCONLY "$PMTK314,0,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0*29"
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 7, 6, 5, 4);
Serial.begin(57600);
Serial.println("Adafruit MTK3329 NMEA test!");
// 9600 NMEA is the default baud rate
mySerial.begin(9600);
// uncomment this line to turn on all the available data - for 9600 baud you'll want 1 Hz rate
mySerial.println(PMTK_SET_NMEA_OUTPUT_RMCONLY);
// Set the update rate
// 1 Hz update rate
// mySerial.println(PMTK_SET_NMEA_UPDATE_1HZ);
// 5 Hz update rate- for 9600 baud you'll have to set the output to RMC only (see above)
mySerial.println(PMTK_SET_NMEA_UPDATE_5HZ);
// 10 Hz update rate - for 9600 baud you'll have to set the output to RMC only (see above)
//mySerial.println(PMTK_SET_NMEA_UPDATE_10HZ);
// set up the LCD's number of columns and rows:
lcd.begin(16, 2);
lcd.setCursor(0, 0);
lcd.clear();
lcd.print("Welcome!");
void loop() // run over and over again
if (mySerial.available())
Serial.print((char)mySerial.read());
/*while (mySerial.available())
int c = mySerial.read();
if (gps.encode(c))
long lat, lon;
unsigned long fix_age, time, date, speed, course;
unsigned long chars;
unsigned short sentences, failed_checksum;
// retrieves +/- lat/long in 100000ths of a degree
gps.get_position(&lat, &lon, &fix_age);
// time in hhmmsscc, date in ddmmyy
gps.get_datetime(&date, &time, &fix_age);
// returns speed in 100ths of a knot
speed = gps.speed();
// course in 100ths of a degree
course = gps.course();
//Setup the dashbard
lcd.clear();
//lcd.print("Spd:");
lcd.print(speed);
That current code will properly display the data through the serial monitor. If take out that large comment then it will give bad data to the serial monitor. If I change the " if (mySerial.available)" to a “while (mySerial.available)” It will print out data which I think is correct on the LCD screen but it wont print to the serial monitor so I can verify.
Basically what I want it to do is print to the serial monitor all the data, and print parsed data to the LCD screen so I can verify that it’s parsing correctly. If you can figure out what I am doing wrong I would greatly appreciate it. I don’t know much about libraries and I am a very terrible programmer.
Thanks all!!!
