GPS Module Not work when connected to ESP8266 via UNO
Condition:
  1. ESP8266 is work when both GPS module NEO-M8N-0-11 connected or not connected to UNO
  2. GPS Module is work when ESP8266 is not connected or just running script for GPS.ino
GPS.ino ← GPS is work when running this file
#include <TinyGPS++.h>
#include <SoftwareSerial.h>
This sample sketch demonstrates the normal use of a TinyGPS++ (TinyGPSPlus) object.
It requires the use of SoftwareSerial, and assumes that you have a
4800-baud serial GPS device hooked up on pins 4(rx) and 3(tx).
static const int RXPin = 8, TXPin = 9;
static const uint32_t GPSBaud = 9600;
// The TinyGPS++ object
TinyGPSPlus gps;
// The serial connection to the GPS device
SoftwareSerial ss(RXPin, TXPin);
ss.begin(GPSBaud);
Serial.println(F(“DeviceExample.ino”));
Serial.println(F(“A simple demonstration of TinyGPS++ with an attached GPS module”));
Serial.print(F("Testing TinyGPS++ library v. ")); Serial.println(TinyGPSPlus::libraryVersion());
Serial.println(F(“by Mikal Hart”));
// This sketch displays information every time a new sentence is correctly encoded.
while (ss.available() > 0)
if (gps.encode(ss.read()))
displayInfo();
if (millis() > 5000 && gps.charsProcessed() < 10)
Serial.println(F(“No GPS detected: check wiring.”));
if(true);
void displayInfo()
Serial.print(F(“Location: “));
if (gps.location.isValid())
Serial.print(gps.location.lat(), 6);
Serial.print(F(”,”));
Serial.print(gps.location.lng(), 6);
Serial.print(F(“INVALID”));
Serial.print(F(" Date/Time: “));
if (gps.date.isValid())
Serial.print(gps.date.month());
Serial.print(F(”/"));
Serial.print(gps.date.day());
Serial.print(F("/"));
Serial.print(gps.date.year());
Serial.print(F(" “));
if (gps.time.isValid())
if (gps.time.hour() < 10) Serial.print(F(“0”));
Serial.print(gps.time.hour());
Serial.print(F(”:"));
if (gps.time.minute() < 10) Serial.print(F(“0”));
Serial.print(gps.time.minute());
Serial.print(F(":"));
if (gps.time.second() < 10) Serial.print(F(“0”));
Serial.print(gps.time.second());
Serial.print(F("."));
if (gps.time.centisecond() < 10) Serial.print(F(“0”));
Serial.print(gps.time.centisecond());
GPSIoT.ino ← ESP8266 is work and number 999 could send to IoT server but GPS is not working and show No GPS detected: check wiring. when I did not hide that line and show
#define RX 2
#define TX 3
String AP = “[My_Wifi_AP]”; // AP NAME
String PASS = “[Password]”; // AP PASSWORD
String API = “[My_Api_Key]”; // Write API KEY
String HOST = “api.thingspeak.com”;
String PORT = “80”;
String field = “field1”;
int countTrueCommand;
int countTimeCommand;
boolean found = false;
double valSensor = 1;
double valLat = 999;
double valLong = 999;
SoftwareSerial esp8266(RX,TX);
TinyGPSPlus gps;
Serial.begin(19200);
Serial.print(F(“Testing TinyGPS++ library v. “)); Serial.println(TinyGPSPlus::libraryVersion());
//ss.begin(GPSBaud);
esp8266.begin(115200);
sendCommand(“AT”,5,“OK”);
sendCommand(“AT+CWMODE=1”,5,“OK”);
sendCommand(“AT+CWJAP=””+ AP +”",""+ PASS +""",20,“OK”);
valSensor = getSensorData();
String getData = “GET /update?api_key=”+ API +"&"+ field +"="+String(valLat);
sendCommand(“AT+CIPMUX=1”,5,“OK”);
sendCommand(“AT+CIPSTART=0,“TCP”,”"+ HOST +"","+ PORT,15,“OK”);
sendCommand(“AT+CIPSEND=0,” +String(getData.length()+4),4,">");
esp8266.println(getData);delay(1500);countTrueCommand++;
sendCommand(“AT+CIPCLOSE=0”,5,“OK”);
int getSensorData(){
esp8266.end();
while(esp8266.available()>0){
Serial.print(“Please Wait for closing Wifi”);
ss.begin(GPSBaud);
//if (ss.available() > 0)
// Serial.print(“GPS OK”);
//Serial.println();
//if (gps.encode(ss.read()))
displayInfo();
//if (millis() > 5000 && gps.charsProcessed() < 10)
//Serial.println(F(“No GPS detected: check wiring.”));
ss.end();
while(ss.available()>0){
Serial.print(“Please Wait for closing GPS”);
return random(1000);
void sendCommand(String command, int maxTime, char readReplay) {
Serial.print(countTrueCommand);
Serial.print(". at command => “);
Serial.print(command);
Serial.print(” ");
while(countTimeCommand < (maxTime*1))
esp8266.println(command);//at+cipsend
if(esp8266.find(readReplay))//ok
found = true;
countTimeCommand++;
if(found == true)
Serial.println(“OYI”);
countTrueCommand++;
countTimeCommand = 0;
if(found == false)
Serial.println(“Fail”);
countTrueCommand = 0;
found = false;
void displayInfo()
valLat=gps.location.lat(),6;
valLong=gps.location.lng(),6;
Could you take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
@cmk__2020
Other post/duplicate DELETED
Please do NOT cross post / duplicate as it wastes peoples time and efforts to have more than one post for a single topic.
Continued cross posting could result in a time out from the forum.
