GPS module that sleeps
Hello, I've been playing with the UBlox 6M GPS module, about $16 from ebay. It works well but doesn't seem to have any sleep functions built into the tinyGPS Arduino library.
Is anyone using a GPS module that can sleep? More importantly, where the GPS library supported by Arduino implements the sleep feature?
Thanks!
You can certainly implement a simple circuit to control the power to a GPS module. Turn it on when you need a location, and then turn it off again. How do you imagine a sleep function to work?
UBlox 6M does have a power saving mode but it looks like it still takes 11ma
Your best bet is either to do as jremington suggests and power it via e.g. a FET which you control using the Arduino,
Or you'll need though all the available specs on what GPS modules are available.
NEO-6M has power saving mode with 11mA current consumption according to the datasheet. But it is still an operating mode, not sleep mode. If you look at it's protocol spec, http://www.ublox.com/images/downloads/Product_Docs/u-blox6_ReceiverDescriptionProtocolSpec_%28GPS.G6-SW-10018%29.pdf and search for "sleep", you'll find it does support sleep mode, but will need to send command to configure it.
How long will it take to re-establish its position after being powered down and restarted?
Does it matter if it takes a few minutes?
…R
