GPS NEO6M not reading meaningful signals
Hello, I am new to the GPS, just got it from this link: GPS module
I follow the instruction for wiring and testing the module. But I did not get useful data.
The blue LED on the GPS module was blinking, so I guess it was fixed.
First step, to check the NMEA message. The code is straight forward:
#include <SoftwareSerial.h>
#include <TinyGPS++.h>
TinyGPSPlus gps;  //declare gps object
SoftwareSerial sc(3,4); //RX pin 3 Tx pin 4
sc.begin(9600);
Serial.println("GPS started");
Serial.write(sc.read());
Then I got these:
21:16:03.757 → ⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮$GPRMC,021604.00,A,4228.48854,N,08329.21376,W,0.088,011220,A6B
21:16:04.226 → $GPVTG,T,M,0.088,N,0.163,K,A
27
21:16:04.259 → $GPGGA,021604.00,4228.48854,N,08329.21376,W,1,08,1.04,291.9,M,-34.8,M,6B
21:16:04.326 → $GPGSA,A,3,07,08,30,21,28,27,01,13,1.73,1.04,1.38
0B
21:16:04.393 → $GPGSV,4,1,14,01,23,147,27,07,83,209,38,08,60,053,32,09,17,203,75
21:16:04.460 → $GPGSV,4,2,14,11,56,128,32,13,12,322,24,14,35,281,30,16,02,082,73
21:16:04.528 → $GPGSV,4,3,14,17,01,220,12,21,38,118,32,27,22,047,29,28,27,277,28
74
21:16:04.630 → $GPGSV,4,4,14,30,59,302,38,51,35,213,32
7A
21:16:04.664 → $GPGLL,4228.48854,N,08329.21376,W,021604.00,A,A*72
21:16:04.734 → ⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮
It seems working, because it shows satellites in GPGSV and position info in GPGGA. However, when I try to read latitude using following code:
   while (sc.available() > 0);
       Serial.println(gps.location.lat(), 6);
I only got zeros
22:52:04.944 → 0.000000
22:52:04.981 → 0.000000
22:52:05.018 → 0.000000
Did I miss something?
Post all the code for that sketch. Read the how get the most out of this forum sticky to see how to properly post code. Remove useless white space and format the code with the IDE autoformat tool (crtl-t or Tools, Auto Format) before posting code.
Look at the DeviceExample.ino example that comes with the TinyGPS++ library to see how to read the GPS and decode the sentences. The way that you are trying is way off.
If I only want a few pieces of info from my GPS I write my own parser using c_string functions like strtok() & atoi().
cx_09:
You did.
Most libraries supply working examples, so when code you write does not work, its worthwhile checking out the examples.
Check in particular how the examples read characters from the GPS and pass them to the TingGPS++ library for decode.
Thanks @groundFungus and @srnet for the reminding. actually the code was from one of the example that’s why I knew TinyGps++. One thing I want to confirm is that, when the blue light is blinking, does it mean it already locked the satellites?
The bottom line, I fixed it. Here is how:
I copied another example and flash it but it won’t work, still showing zeros. I moved the board outdoor and stayed for 15minutes in snow but nothing magical happen other than freezing nose.
  TinyGPSPlus_GPS_Shield.ino
  TinyGPS++ Library Example for the SparkFun GPS Logger Shield
  By Jim Lindblom @ SparkFun Electronics
  February 9, 2016
  https://github.com/sparkfun/GPS_Shield
  This example uses SoftwareSerial to communicate with the GPS module on
  pins 8 and 9. It uses the TinyGPS++ library to parse the NMEA strings sent
  by the GPS module, and prints interesting GPS information to the serial
  monitor.
  After uploading the code, open your serial monitor, set it to 9600 baud, and
  watch for latitude, longitude, altitude, course, speed, date, time, and the
  number of visible satellites.
  Resources:
  TinyGPS++ Library  - https://github.com/mikalhart/TinyGPSPlus/releases
  SoftwareSerial Library
  Development/hardware environment specifics:
  Arduino IDE 1.6.7
  GPS Logger Shield v2.0 - Make sure the UART switch is set to SW-UART
  Arduino Uno, RedBoard, Pro, etc.
#include <TinyGPS++.h> // Include the TinyGPS++ library
TinyGPSPlus tinyGPS; // Create a TinyGPSPlus object
#define GPS_BAUD 9600 // GPS module baud rate. GP3906 defaults to 9600.
// If you're using an Arduino Uno, RedBoard, or any board that uses the
// 0/1 UART for programming/Serial monitor-ing, use SoftwareSerial:
#define ARDUINO_GPS_RX 9 // GPS TX, Arduino RX pin
#define ARDUINO_GPS_TX 8 // GPS RX, Arduino TX pin
SoftwareSerial ssGPS(ARDUINO_GPS_TX, ARDUINO_GPS_RX); // Create a SoftwareSerial
// Set gpsPort to either ssGPS if using SoftwareSerial or Serial1 if using an
// Arduino with a dedicated hardware serial port
#define gpsPort ssGPS  // Alternatively, use Serial1 on the Leonardo
// Define the serial monitor port. On the Uno, and Leonardo this is 'Serial'
//  on other boards this may be 'SerialUSB'
#define SerialMonitor Serial
  SerialMonitor.begin(9600);
  gpsPort.begin(GPS_BAUD);
  // print position, altitude, speed, time/date, and satellites:
  printGPSInfo();
  // "Smart delay" looks for GPS data while the Arduino's not doing anything else
  smartDelay(1000);
void printGPSInfo()
  // Print latitude, longitude, altitude in feet, course, speed, date, time,
  // and the number of visible satellites.
  SerialMonitor.print("Lat: "); SerialMonitor.println(tinyGPS.location.lat(), 6);
  SerialMonitor.print("Long: "); SerialMonitor.println(tinyGPS.location.lng(), 6);
  SerialMonitor.print("Alt: "); SerialMonitor.println(tinyGPS.altitude.feet());
  SerialMonitor.print("Course: "); SerialMonitor.println(tinyGPS.course.deg());
  SerialMonitor.print("Speed: "); SerialMonitor.println(tinyGPS.speed.mph());
  SerialMonitor.print("Date: "); printDate();
  SerialMonitor.print("Time: "); printTime();
  SerialMonitor.print("Sats: "); SerialMonitor.println(tinyGPS.satellites.value());
  SerialMonitor.println();
// This custom version of delay() ensures that the tinyGPS object
// is being "fed". From the TinyGPS++ examples.
static void smartDelay(unsigned long ms)
  unsigned long start = millis();
  do
    // If data has come in from the GPS module
    while (gpsPort.available())
      tinyGPS.encode(gpsPort.read()); // Send it to the encode function
    // tinyGPS.encode(char) continues to "load" the tinGPS object with new
    // data coming in from the GPS module. As full NMEA strings begin to come in
    // the tinyGPS library will be able to start parsing them for pertinent info
  } while (millis() - start < ms);
// printDate() formats the date into dd/mm/yy.
void printDate()
  SerialMonitor.print(tinyGPS.date.day());
  SerialMonitor.print("/");
  SerialMonitor.print(tinyGPS.date.month());
  SerialMonitor.println(tinyGPS.date.year());
// printTime() formats the time into "hh:mm:ss", and prints leading 0's
// where they're called for.
void printTime()
  SerialMonitor.print(tinyGPS.time.hour());
  SerialMonitor.print(":");
  if (tinyGPS.time.minute() < 10) SerialMonitor.print('0');
  SerialMonitor.print(tinyGPS.time.minute());
  if (tinyGPS.time.second() < 10) SerialMonitor.print('0');
  SerialMonitor.println(tinyGPS.time.second());
Then I switched to another Uno board, but initially it won’t upload. It said “/dev/tty.usbserial-1420” not found. I found in the menu Tools → Port /dev/tty.usbserial-1420 and the serial port was not checked, then I checked it, and flashing went through, and data received successfully.
So maybe that cause the issue with my first Uno board. So I switched back to the first one and ensure the serial port was checked, then all data received properly.
Then I tried my own code. I compared it with the example and found myself silly to make the mistake: I forgot the encode command .“gps.encode(gpsPort.read());”. Now my code is working as well.
SoftwareSerial sc(8,9); //RX pin 3 Tx pin 4
#define gpsPort sc
  gpsPort.begin(9600);
 Serial.print("lat"); Serial.println(gps.location.lat(), 6);
cx_09:
The blinking light, on most GPSs, indicates that the GPS has valid time sync, although the displayed time may be a second or two different to UTC.
Often time sync accours around the same time as the GPS gets a position fix, but not always. You can have time sync (and a flashing LED) but no position fix.
